Blue Torch Fab Sport Cage kit install - JeepForum.com
post #1 of 7 Old 05-25-2011, 12:48 PM Thread Starter
92 Green YJ
92 Green YJ's Avatar
Well after many years and a few close calls recently, I decided it was finally time to do a proper roll cage in the YJ. I spent a lot of time researching the various add on cage kits on the market and decided to go with the new sport cage kit from Blue Torch Fabworks to use as the base for my build. for the price it was the most complete kit. I got the kit in a few days ago, and on first inspection, it lived up to Blue Torches reputation and quality.
Now, many years ago when I didn't know any better, I had removed the factory spreaders and replaced them with a homebrew sport cage made of, well, not good material at all. A combination of pipe and glorified exhaust tube for the spreaders. Lets just say I've been very lucky to have never rolled with it. So the first order of business was to remove the components from my overhead console and cut out the old crap. I started with a 4.5" cut off disc, but quickly realized it would take me all day. So out came the Plasma cutter which made short work of removing the old bars
Then I used a cut off wheel, grinding disc, and flap disc to remove the leftovers from the B pillar and smooth it all out. Then the installation of the new could begin. Here you can see the difference between what I had, and the new 1.75"x.120 wall DOM in the kit
First thing to be fit was the windshield spreader on the passenger side. I removed the old plate from the windshield, installed the one from the kit, ground down the original header support tube so the new bar would slide over it nicely and ended up having to motivate it up a little with a BFH. Blue Torch says to remove these, but I felt it couldn't hurt to have a little extra support at the B pillar joint so I decided to leave them as slugs instead.
Next I had to mock in the A pillar down tube. I slid it in with the foot plate and decided where I wanted it, tacked the foot plate to the bottom of the tube and pulled it out to finish welding the 1/4" floor plate to the bottom of the A-pillar tube, then I set the A pillar back in, marked the bolt holes and drilled them. Mounted the foot to the floor and welded the top to the spreader.
the A pillar follows the dash very nicely!!
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #2 of 7 Old 05-25-2011, 12:49 PM Thread Starter
92 Green YJ
At this point I repeated the same process on the passenger side. The next step was the dash bar which dropped right into place like butter. Couple quick passes and its welded in at the front and top. When i am done with my additions I will remove the entire cage so I can do the finish welding and get to the bottom and back of the dash bar and the other area I couldn't get to or get to comfortably to get a good weld on it.
After the dash bar was in I went to install the top spreader from A to A. this was the only bar I had to modify a little bit to get in, but looking back It was because I had gotten ahead of myself. I should have put the dash bar and the header bar in prior to welding the windshield plates and it would have fit no problem. So I had to cut it down a touch to get it to fit. Once that was resting in, I measured and set in the middle B to A header spreader bars. When everything was where I wanted it I burned it all in. Since I am not done with the additions I just threw a coat of weld thru primer on the whole thing and called it a day. In some pics you will see areas that were not finished welding, again due to my dislike of welding upside down or having to work at an akward angle. these joints will be done when I remove the cage.
Overall the Blue Torch kit was just fantastic to put in. everything was cut and notched perfectly. Some instructions or at least suggestions as to what order to do everything in would have been nice, but it is a DIY kit, so.
Still to be done and added to the cage:
windshield V bars
Seat and harness mounts
Door bars
Some additions to the factory rear section
X bar on the B pillar
Lower B to C bars
C to C bar
Rearview Mirror mount on the cage
Overhead console in the spreaders
mount plate on the dash bar for a RAM mount base for GPS and such
My
post #3 of 7 Old 05-25-2011, 01:10 PM
giggityjeeper
windshield V bars
Door bars
Some additions to the factory rear sectionX bar on the B pillar
Lower B to C bars
C to C bar
my rear... I doing the front much like yours now, but just using old rollbars for salvaged jeeps.... for therear I used my sport bar and a falmily bar out of a TJ.... cut it all to fit and welded into place....
I like your in the front, Ima follow this pattern if it is ok with you?
my thread on how i did it
http://www.jeepforum.com/forum/f12/f...grade-1054753/
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #4 of 7 Old 05-25-2011, 01:22 PM Thread Starter
92 Green YJ
be my guest. I just took a ton of measurements to come up with how much tube i am gonna need to finish it the way i want it. Looking at about 25 feet of 1.75" and 15 feet of 1"
My
post #5 of 7 Old 05-25-2011, 01:40 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Looks real nice Scott!
Joe Dillard is online now
post #6 of 7 Old 05-25-2011, 01:59 PM Thread Starter
92 Green YJ
thanks Joe, its a start. Gonna borrow your idea of the perforated sheet for the overhead console. I really like the way that looks on yours
My
post #7 of 7 Old 08-27-2011, 09:49 AM
Sgt.Fuzz
Subbed for reference.
My build:
Sgt.Fuzz is offline
Rock Hard Sport Cage Install Problem rymanrph TJ Wrangler Technical Forum 90 07-17-2012 01:59 PM
A to Z Sport Cage and Install Price? ROLLTIDEtj TJ Wrangler Technical Forum 10 05-13-2010 01:49 AM
Blue torch fab. joeevans1 TJ Wrangler Technical Forum 7 02-02-2010 08:50 PM
Blue Torch Fab GDog984 TJ Wrangler Technical Forum 0 05-23-2007 07:52 AM
Rock Hard 4x4 sport cage install on an 06 ISurvivedNMU TJ Wrangler Technical Forum 17 09-24-2006 07:47 PM
