Blowing starter fuse - JeepForum.com
post #1 of 9 Old 08-15-2005, 02:51 PM Thread Starter
PAOLOME
Hey Folks,
I keep blowing my 40 amp starter fuse in my fuse block next to the battery. Any suggestions where to start trouble shooting?
The only extra electrical stuff I've added is my stereo deck.
Thanks and Aloha.
Paolo
Green/Spice '94 YJ, SOA, 35's, yadda, yadda, yadda.......just WAVE if you see me!!! ALOHA!!!
PAOLOME is offline
post #2 of 9 Old 08-15-2005, 06:14 PM
mat626
do you possibly have a bad starter? you could try putting in a larger fuse to fix the problem till you find out whats wrong
mat626 is offline
post #3 of 9 Old 08-15-2005, 06:26 PM
xeon
If you put a larger fuse in, you can damage your Jeep even more. You can burn the wires and what not out. Does the start work? Are you able to start the Jeep? There is a short somewhere. Keep looking and start cleaning the starter wire ends and make sure they dont touch . Make sure you pull the negetive wire off battery before you do any work. Hope this helps!
88YJ, 350TBI, 700R4, Atlas 4.3, HP60, 14B (At a mall near you)
Tri-State (NJ-NY-PA) 4x4 Wheeling Group
xeon is offline
post #4 of 9 Old 08-15-2005, 07:27 PM
RB_
ditto on what xeon just told you. Starter cable or maybe a wire running off the batt.....if no luck i would pop the starter and do a bench test(take to you're local parts store and ask them to do it if you dont have access to the tools/meters most will do it for free) is the fuse blowing when you try to start or just turn the key on or even with key off?
92 Jeep Renegade
4.0 HO 5spd
work in progress
"Ugly Jeep Rescue League" Member #1
RB_ is offline
post #5 of 9 Old 08-15-2005, 07:30 PM
zolon
zolon's Avatar
When you take it in to get bench tested, make sure they do it more then once. Had a starter for a different car that the pinion gear would stick on once in awhile. This would cause it to over amp. But it didnt' ALWAYS do it.. On the third time I took it in to get started, it stuck.
2012 Jeep Wrangler Sport - Silver - Build Date 2-27-2012
1999 Safari Zanzibar 38' Diesel Pusher (Full Time Home)
zolon is offline
post #6 of 9 Old 08-15-2005, 08:34 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
i'd check the cables and the terminals for loose connections and corrosion before pulling the starter. either one can cause a voltage drop at the starter and cause it to overdraw on the amps. slice the insulation of the cables lengthwise at the ends and have a look underneath too. I've seen cables that look fine until you look under the insulation. start with the easy stuff
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #7 of 9 Old 08-15-2005, 10:13 PM Thread Starter
PAOLOME
Right on fellas! I've blown 40 and 50 amp fuses as soon as I put them in. Only on one occasion did I put a 40 amp fuse in and the Jeep started fine only to blow it again 3 hours later.
I'm going to clean, inspect, and tidy up the connections and see if that does the trick. If not then I'll get the starter bench tested and probably just replace it since its probably due for a replacement.
Thanks again for the help!
Paolo
PAOLOME is offline
post #8 of 9 Old 08-15-2005, 10:34 PM
Lager
Never replace a fuse thats blowing with a larger value, you could do some great harm to your electrical system. Does your fuse blow when you first put it in, or when you hit the key to start? Our Jeeps are getting old, so sometimes we have to repair things that other owners have done. An alarm taps into the starter wire under the dash ( most times) and if the connection is poorly done, then maybe thats causing your problem because it's shorting to ground. If you don't have an alarm , I would guess that your starter motor is going bad.
Good luck.
Lager is offline
post #9 of 9 Old 07-31-2013, 01:19 AM
UTTKE
Ok I have the same problem, but when I put a new starter in, it will start. then an hour or a day or a week will go by and then I go to start and it grrr then nothing. Fuse blows.
I have changed my coil, starter, twice now and even had custom battery cables made.
I need some ideas here. I cant even start it and I am going crazy.
UTTKE is offline
Fuse 26 Keeps Blowing? Jeep-5O TJ Wrangler Technical Forum 20 07-11-2015 12:30 AM
Fuse blowing tonylax48 YJ Wrangler Technical Forum 3 08-12-2009 10:56 PM
Help Blowing Ign Fuse Je4x4ep YJ Wrangler Technical Forum 0 07-10-2009 10:34 PM
'94 Keeps Blowing Fuse ThatHumble YJ Wrangler Technical Forum 11 06-09-2008 06:36 PM
I keep blowing the fuse! BunnyHunter TJ Wrangler Technical Forum 1 09-20-2004 09:41 AM
