blowing my fuse - JeepForum.com
post #1 of 16 Old 03-27-2005, 07:16 PM Thread Starter
garbo1954
1990 WJ
blowing my fuse
Having a run of electrical problems on my YJ . Tail lights and parking lights quit working - is this the gold metal fuse that is about and inch square ? No instrument panel lights - fuse looks good but when I put circuit tester on either side of fuse contacts I don't get any current on either one - anybody with any idea where to look next ? Need to take it to PC Monday for Spring break but would really like to have tail lights - insrument panel lights I can do without if I have to( I can allways use a flash light . Thanks.
1990 YJ-258-5sp-3.5BDS-33x12x12.50 BFGMT's-AR136's-AA SYE-CV/DS-WARNxd9000i-in cab control-OlympicBumps-& stinger-Throttle control-Weber551--PosiLock--Aussie locker front& Detroit in rear 4.88 gears, super 35 axles, Bushwacker flares, Bestop seats, mastercraft seatbelts,Tuffy console, Tractor supply tool box -
2003 Rubicon-2"Skyjacker-33x12.50x15 Super Swampers-MT Classic II-Jeeperman bumpers-WarnXD9000i-Brute Force Cold air-
garbo1954 is offline
post #2 of 16 Old 03-27-2005, 07:21 PM
wherndon
What the hell?
wherndon's Avatar
fuses are cheap.
try swapping another one in it's place.
if it works, you are good to go.
________________________________
'05 Rubi, Patriot Blue, RE SF, Antirock, Warn, Fabtech, Tomken
_________________________________
2000 Grand Cherokee Laredo V8, Patriot Blue
Stock
'93 YJ Sport, Canyon Blue
4.0, auto, air, limited slip, HT.
2.5" Rancho suspension, Ramsey 8000
Previous Jeeps...
'91 XJ Laredo, white
'87 YJ Sport, white
wherndon is offline
post #3 of 16 Old 03-27-2005, 07:25 PM Thread Starter
garbo1954
1990 WJ
Thanks, tried a new fuse for the insrument panel but it didn't help, still don't know why there is no porer on either side , I will get one of the big metal fuses Monday and give it a try for the tail lights. Thanks
post #4 of 16 Old 03-27-2005, 07:31 PM
JT29
Make sure you have a good ground.
JT29 is offline
post #5 of 16 Old 03-27-2005, 07:35 PM Thread Starter
garbo1954
1990 WJ
If you mean the tester ground , I checked other fuse connections and it beeped. If you mean another type or place for a ground , I just assumed the fuse panel was grounded . Thanks
post #6 of 16 Old 03-27-2005, 09:11 PM
mrgeoff
I had the same problom a few years ago and it was my relay. on my 93 all that is on the same circuit. Dont forget you have a fuse box out side under hood. just a thought
93, 4 bangin, gutless yj that is ready to crawl this summer.
mrgeoff is offline
post #7 of 16 Old 03-27-2005, 09:57 PM Thread Starter
garbo1954
1990 WJ
Thanks , I will try to find the relay in the morning.
post #8 of 16 Old 03-27-2005, 10:46 PM
BzJeep
BzJeep's Avatar
Oh wow... dude, I was in the exact same boat as you but it took me like a week to figure all of it out!
We went through countless fuses and FINALLY figured out that up in the front where the front marker and signal lights go through, the wires were being pinched against the sheet metal and the insulation had been cut through so since somehow, the instrument panel lights, tail and signal lights are all linked together, it kept shorting out whenever the Jeep jiggled the "right" way... I also had to replace the relay though, aswell as patch up those shorts. Get a good Chiltons or Haynes manual and check out the schematics, they really help a lot in narrowing down the problem.
2008 Metropolitan Gray Mazda3S Sport
2001 Steel Blue Grand Limited *SOLD*
1993 Forest Green Wrangler *SOLD*
Green Jeep Club Member #16
BzJeep is offline
post #9 of 16 Old 03-28-2005, 01:20 PM
Junker 91 YJ
I had the same thing happen to me, but it kinda sucked beacause it ended in a DUI...... Anywho I searched through all the fuses and found nothing, then relays, then wiring.... come to find out its the switch itself. That thing was dirty as hell so i hit it with some WD40, shined it up and POW works like a champ
Black on black on black on black on black.
Junker 91 YJ is offline
post #10 of 16 Old 03-28-2005, 05:03 PM Thread Starter
garbo1954
1990 WJ
Just tried the 5.3 fuse ,it didn't help. Should have a new awitch from Qudratec today, I guess I will keep going until I replace everything to include the tires.
post #11 of 16 Old 03-28-2005, 07:49 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
no power from the fuse block at fuse 8 (20 A fuse in the third row down) means you have a bad wire between the fusible link (it can't be the link itself or else you wouldn't have any head lights) and the fuse block. either it's broken or there's a bad connection at the block or where it splices in with the line to the main part of the headlight switch. if you have no power at fuse 8, then you won't get any at fuse 10 (5A fuse in the lower left corner for the gauges). if you have no power at fuse 10, but power at 8, then it's likely your headlight switch. so which fuse did you test?
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #12 of 16 Old 03-28-2005, 10:00 PM Thread Starter
garbo1954
1990 WJ
Just went out and double checked I have power on the right side of fuse 8 and the fuse is not blown. As I understand your post my problem should then be my headlight switch . You don't know how much I apppreciate you taking the time to help with this. As I said earlier I plan on changing the switch tomorrow after that it would have been on to the dealership $$$$. I still do not have any power in fuse block 9 acc lps and all my lights in my dash have stopped working , the 4 guages plus the tack and speedometer any connection to the above problem ? Again , thanks a bunch.
post #13 of 16 Old 03-28-2005, 10:23 PM
sentinal02
sentinal02's Avatar
since you lost both tail/park lights and the gauges the headlight switch is the likely suspect. anything else would have to be loose/bad wires. fuse 9 though doesn't power the gauges and is only hot when the key is on. if you're testing that then make sure the key is on. that's the 15A fuse to the right of the 20A you tested for the headlight switch. the one controlling the gauges is fuse 10, down in the lower left corner of the block. you won't get power there unless your tail lights are operating (the headlight switch feeds power to the dimmer wheel and then fuse 10 draws power off the wheel before going to the gauges) so don't expect to have gauge lights until you get the tail lights fixed. if you get your tail lights working and the gauges don't come back, check that fuse for power and if you get nothing, pull the wheel and check to make sure you have power coming in when the headlights are on. since they all went at the same time though, the headlight switch will likely solve the problem. keep us posted
post #14 of 16 Old 03-28-2005, 10:51 PM Thread Starter
garbo1954
1990 WJ
HOUSTON ---NO MORE PROBLEMS--!!!!! Thanks, Sentinal02 , I couldn't wait , since I had the new light switch I stayed up late and put it in and WAHLAH!!! tail lights and guage lights. How do you guys know this stuff in such detail. I amayzed and thankful for the help. AWESOME!!!Thanks, again.
post #15 of 16 Old 03-28-2005, 11:04 PM
sentinal02
sentinal02's Avatar
all that stuff just came from reading the wiring diagram in my chilton's manual. not hard at all. glad it's working
Fuse 26 Keeps Blowing? Jeep-5O TJ Wrangler Technical Forum 20 07-10-2015 11:30 PM
Help Blowing Ign Fuse Je4x4ep YJ Wrangler Technical Forum 0 07-10-2009 09:34 PM
fuse keeps blowing srjeepguy TJ Wrangler Technical Forum 2 12-02-2008 09:14 PM
YJ Fuse keeps blowing smitkev2 YJ Wrangler Technical Forum 3 10-17-2008 09:09 PM
'94 Keeps Blowing Fuse ThatHumble YJ Wrangler Technical Forum 11 06-09-2008 05:36 PM
