Blowing Gauges Fuse Over and Over - JeepForum.com
post #1 of 2 Old 02-18-2013, 02:09 PM Thread Starter
redbullrr
1987 YJ Wrangler
I have went thru about 15 fuses. Sometimes it works most of the time it blows out rite away. Clearly there is a grounding issue. Does anyone know if I can rewire the gauges or is there a ground I should be looking for to re-run a new ground?
It's specific to the fuse for my RPM, and gauges.
redbullrr is offline
post #2 of 2 Old 02-18-2013, 04:04 PM
Que89YJ
You need to pull the cluster. There is a common issue with corrosion on the connectors. Look up using a light bulb to troubleshoot to save you some fuses while you figure out whats wrong.
Que89YJ is offline
