Blowin out u joints once a week!!! HELP.... - JeepForum.com
post #1 of 14 Old 12-01-2001, 07:00 PM Thread Starter
JACKED
OK dont know what going on. Its been lifted for about 3yrs with no probs and all of a sudden a couple of weeks ago I broke the bolt that holds the straps for the U joint to the rear yoke. Used easy out to get broken bolt out and just replaced rear u-joint and put new bolts and straps, well just broke again. 3rd time in a month and I havent even taken it off rode once this month. is there a way I can jump up to a heavier duty yoke that will hold bigger straps and like a 5/8th bolts. and maybe some heavier duty u joint? well will replace with new stock u joints till can figure some ideas out. thanx for any help!
93 YJ 4.0L 5 speed. 3" body and 4" suspension lift. 35x12.5 MT tires.
JACKED is offline
post #2 of 14 Old 12-01-2001, 07:05 PM
evilpsych
evilpsych's Avatar
well you can convert from the straps to U-Bolts.. there's a how-to somewhere out there on the net.. i suggest you get your driveshaft balanced.. you may have installed it incorrectly, i.e. out of balance.
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 14 Old 12-01-2001, 07:06 PM
evilpsych
evilpsych's Avatar
oh.. have you considering a double cardan or CV driveshaft? perhaps your drivetrain angle is too high
A
post #4 of 14 Old 12-01-2001, 07:10 PM Thread Starter
JACKED
I have a t- case lowering kit, and its been lifted for about 3yrs with NO PROBS so I dont think its the drive angle, but could definatly need to be balanced. thanx!
JACKED is offline
post #5 of 14 Old 12-01-2001, 07:15 PM Thread Starter
JACKED
Also never heard of a double cardan, could u explain.
JACKED is offline
post #6 of 14 Old 12-01-2001, 08:26 PM
Darko
All us jeepers hate to hear this, but maybe you installed it wrong. Did you install the lift 3 years ago, or did somebody else do it.
Found a 85 CJ7 tub in good shape with
minimal rust. The resto continues....
Darko is offline
post #7 of 14 Old 12-02-2001, 12:58 AM
osburn
osburn's Avatar
I'd suspect a bad yoke. When you blow out a joint, it commonly damages the yoke. Since it wasn't a problem before, and it's recurring, that would be my first guess.
Oh, one more possibility. You're running a Dana 35 I presume? The tubes can sometimes spin. Look at the diff very carefully. See if one of the holes in the rear shows a wear spot that looks like a 1/4 moon. Another way to tell is look at your perches. Are they both perfectly parallel?
I had the tubes spin on my Dana 35. Had to weld them to the pumpkin. It's a pretty common failure on SOAs actually. It's probably actually due to 33" tires. But it used to be you'd only see YJs with 33s on SOAs.
Matt Osburn
Score 1032
osburn is offline
post #8 of 14 Old 12-02-2001, 09:14 AM Thread Starter
JACKED
I am going to work on it today and ill post everything I find out. oh had a shop called Rigs put in the lift kit, they specialize in lifted trucks but mostly Jeeps. OH how can I tell if the Yoke is bad. IT looks fine after visual inspection, but Im NOT a mechanic.
JACKED is offline
post #9 of 14 Old 12-02-2001, 01:06 PM
osburn
osburn's Avatar
The cap should fit perfectly. Zero slop.
Matt Osburn
Score 1032
osburn is offline
post #10 of 14 Old 12-02-2001, 01:57 PM Thread Starter
JACKED
huh? what cap?
JACKED is offline
post #11 of 14 Old 12-02-2001, 02:27 PM Thread Starter
JACKED
Yeah Osborn, the rear yoke is JUNK. were the U joint sits inside the yoke the metal is just all chewed up. so guess ill need a new yoke and while thats being replaced Ill have the drive shaft balanced and front and rear U-joints replaced. Is there such a thing as a heavier duty U joint or a way to beef that up alittle so this won't happen again, if there is can someone link me too a site where I can buy some. Thanx everyone exspecially OSBORN!
JACKED is offline
post #12 of 14 Old 12-02-2001, 06:04 PM
osburn
osburn's Avatar
Yeah, you can beef up that joint. Buy new yokes for a larger sized u-joint. Get new yokes for the pinion and the driveshaft. I really don't know for sure if a 1310 yoke is available for the Dana 35, but I'd guess that it is. Getting a 1310 fitted onto your tcase would be a little tougher I'd guess. But, when it comes to Jeep mods, anything can be done.
Matt Osburn
Score 1032
osburn is offline
post #13 of 14 Old 12-03-2001, 06:42 AM Thread Starter
JACKED
Thanx everyone again u were all very helpfull!
JACKED is offline
post #14 of 14 Old 12-03-2001, 06:54 AM
cobra54
If I was going to have to go to that much trouble and expense, I think I'd just go with a new shaft with a double cardan.
93 Red YJ 2.5L
94 Red F-150 X Cab 5.0L
01 Black Cobra 4.6L DOHC
02 ZX3 Focus 2.0L DOHC
cobra54 is offline
'94 YJ's dash quit workin, keeps blowin fuses jeepyj7037 YJ Wrangler Technical Forum 13 03-02-2009 06:11 AM
98 TJ Heat is blowin cold air! Schmoog TJ Wrangler Technical Forum 10 01-04-2007 09:26 AM
PDC fuse keeps blowin out on me. Help! bgs865 TJ Wrangler Technical Forum 2 03-20-2006 09:31 AM
Blowin' fuses spydermonkey YJ Wrangler Technical Forum 6 10-03-2004 08:47 AM
