Blower Motor Resistor - 87 YJ - JeepForum.com
post #1 of 18 Old 12-05-2009, 12:53 PM Thread Starter
DivineKaos
Hello all,
Blower motor resistor died, have another one on the way- gonna be about a week before I get it. Meanwhile, there is a winter storm warning in affect.
I was told to bypass it, how would be the way to do this. I will take it being either Off or full on. Either way- I need the heat. Can someone please help me out?
All wiring is still stock, so color codes will be relevant.
Thanks!
"A man has to know two things in life, limitations and priorities. You let your priorities get in the way of your limitations." - MrBlaine
DivineKaos is offline
post #2 of 18 Old 12-06-2009, 01:46 AM
Opihi59
from here it gets rough
Opihi59's Avatar
Someone else chime in if you have a response, but in my experience when the blower resistor goes out, you end up with single speed blower which works only on High.
Is there anything else in your system that could be causing a problem, like fuse etc?
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 18 Old 12-06-2009, 07:15 AM
Que89YJ
x2. You should be able to just leave the old resistor installed and it should default to high speed until you get the new one. If that is not happening then you need to see what else is bad.
Que89YJ is offline
post #4 of 18 Old 12-07-2009, 07:50 AM
Matt The Hammer
If your resistor has totally died (no power) you can pull the harness from the toggle/reisitor and make a jumper.
I just got my new resistor myself. It's sitting on my dining room table.
2013 JKU
1995 YJ
Matt The Hammer is offline
post #5 of 18 Old 12-07-2009, 08:18 AM
kgillette
I ordered mine from pepb0ys last week, it was like $12 after taxes. 3-5days shipping though... hopefully it will be in today, im dy'n to try out my blazer blower motor upgrade...
88 Wrangler - Build Thread: http://www.jeepforum.com/forum/f12/88-yj-fix-turned-build-956202/#post8758947
kgillette is offline
post #6 of 18 Old 12-08-2009, 04:28 AM
kgillette
Well I called pep-boys to check on my resister and well if your in the Rochester area think twice about ordering parts from them.. I called to find out that the order had been canceled last week by the vendor, no call to me from pepboys, so they said that they would find it locally and call me back in a few hours, and of course I did not get a callback. Hopefully when i call they will have good news (not holding my breathe)
post #7 of 18 Old 12-14-2009, 09:57 AM
kgillette
where did you get your new one I found out that the resistor is supposedly on national back order.
post #8 of 18 Old 12-14-2009, 10:37 AM
kloppk
I was just looking at the 1993 wiring diagram for the blower circuit.
Assuming the 89 is the same the fan ought to work on the High setting with or without the resistor.
The resistor only provides power for the Low and Medium speed settings.
If the fan isn't working on High then it may not be the resistor.
Could be Fuze 12 25 amps, the blower switch itself, the motor or the vent switch in the heater control panel.
The vent switch kill the fan when the controls are set to Vent mode.
kloppk is offline
post #9 of 18 Old 12-14-2009, 10:44 AM
Que89YJ
National back order? Take a look around on line. Napa JC Whitney, etc. They are a real common part and should be easy to come by.
Que89YJ is offline
post #10 of 18 Old 12-14-2009, 10:53 AM
kgillette
I thought they would be (everywhere, widely available). Autozone had them on their site a week or so ago, now they don't. I'll check with NAPA...
post #11 of 18 Old 12-14-2009, 11:16 AM
kgillette
NAPA cant get it anymore, was only $3 before it vanished. Just got off the phone with them its no longer listed as an available part from their supplier
post #12 of 18 Old 12-14-2009, 11:18 AM
Que89YJ
Check autozone, advanced etc. They do have them.
AutoZone.com | RelayandResistors | Reddotunits71R-1450blowerresistorblock
Que89YJ is offline
post #13 of 18 Old 12-14-2009, 11:33 AM
kgillette
Saw that one. I wanted to stay OEM. Guess I may not have a choice...
post #14 of 18 Old 12-14-2009, 02:26 PM
Opihi59
Opihi59's Avatar
Lord. If I lived in Rochester I'd put just about anything in there to make it thru the winter with most of my toes intact.
Opihi59 is offline
post #15 of 18 Old 08-30-2012, 10:53 AM
redbullrr
1987 YJ Wrangler
Sorry for bringing this from the dead but I'm baffled at the moment. My heater for a while only worked on high. Then out of no where I had medium and high. Now I have jack Crap. Anyway I can here it try for a second but get nothing. Do I need a new blower motor?
redbullrr is offline
If it's not my blower motor resistor, it's my what??? blower still doesn't turn on.. bortz1892 TJ Wrangler Technical Forum 13 08-02-2010 09:13 PM
blower motor resistor XJKyle1389 TJ Wrangler Technical Forum 2 11-10-2009 02:06 PM
YJ Blower motor resistor UltimatE Wrangler General Discussion 3 10-21-2008 07:00 AM
Blower motor resistor? crazbuck14 TJ Wrangler Technical Forum 0 12-06-2007 03:05 PM
blower motor resistor $$$$$ mudluva TJ Wrangler Technical Forum 6 02-27-2007 12:51 PM
