Blow-by? Can someone educate the uneducated? - JeepForum.com
post #1 of 4 Old 04-05-2002, 07:25 AM Thread Starter
mopar_man
I had a post about what to look for when buying a Jeep. Someone said to check for blow-by and didn't elaborate on what this is. Can someone tell me? I think I'm going to look at one this weekend so any and all quick responses would be appreciated.
1987 Wagoneer
4.0/auto
Fully loaded and totally stock......for now
mopar_man is offline
post #2 of 4 Old 04-05-2002, 08:50 AM
4wheeler4CJ
4wheeler4CJ's Avatar
A simple indication of "blow-by" is oil leaking out at the PCV Valve, or, even worse, is oil leaking out at the gaskets (valve cover, fuel pump if older motor, LOL, Rear Main, Head, etc.)
Blow By is the compression in the cylinder leaking back past weak rings, causing positive pressure in the crankcase, ultimately causing oil to push out of any available openings, and, when worse, it makes it's own openings to come out.
The real method to check blowby is by doing a compression test. If you check the threads on here, it is explained more in detail. Do a search for "blow by", and you should pull up a few posts we have had. <img border="0" title="" alt="[Wink]" src="wink.gif" />
4wheeler4CJ is offline
post #3 of 4 Old 04-05-2002, 08:50 AM
4wheeler4CJ
post #4 of 4 Old 04-05-2002, 09:43 AM Thread Starter
mopar_man
Ah. Very good Thank you. I've only ever bought 3 vehicles, one which I was replacing the engine on already and the other 2 didn't leak anything so I was lucky on those.
1987 Wagoneer
4.0/auto
LCG Builders-Educate Me cmgorman94 TJ Wrangler Technical Forum 19 01-20-2010 10:33 AM
Educate me: What is this? VanBCguy TJ Wrangler Technical Forum 20 10-23-2009 07:55 AM
Educate me about winches Cross YJ Wrangler Technical Forum 12 04-11-2008 05:54 PM
Educate me on the YJ 83seejay7 YJ Wrangler Technical Forum 10 09-08-2007 11:35 AM
Educate me on JKS Disconnects hardwarp TJ Wrangler Technical Forum 20 12-21-2004 10:25 PM
