Blow back -
Go Back > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Blow back
SWAG Off Road, Cyber Monday Sale, Our Only Sale Of The YeaSwag off road cyber monday sale, our only sale of the yearAll Bilstein shocks & struts - Lowest Prices Ever and
Unread 11-22-2015, 04:24 PM   #1
Blow back
my 88 2.5 wrangler is leaking oil out of the oil fill cap. What is clogged?
willjeep60 is offline   Reply With Quote Quick reply to this message
Unread 11-22-2015, 04:32 PM   #2
Check your pcv valves... If you take them off and shake them you should be able to hear something moving in them.... Check all the hoses to them and also take off your valve cover and clean the baffles... All culprits for blow-back or blow-by...
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
jaycal3 is offline   Reply With Quote Quick reply to this message
Unread 11-22-2015, 06:10 PM   #3
Is there oil in your airbox? is there oil coming out of the orifice on the PCV/CCV ports? if no to these questions - it may just be as simple as you need a new oil cap.
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
bruinjeeper is offline   Reply With Quote Quick reply to this message
Unread 11-22-2015, 06:31 PM   #4
Drednot's Avatar
Don't bother messing around checking the PCV valve, just put in a new one. Rattle or not, they need to flow a specific rate. Trace all the rest of the PCV lines and pull them to clean them out and make sure there are no leaks, cracks, hacks, or restrictions. Then inspect your oil cap. If the rubber gasket is cracked, hardened, or just doesn't seal snugly, replace the cap.
I've has more than one 2.5L that had the PCV vacuum port at the base of the throttle body completely blocked by hard crust deposits. Cleaned the port and voila, the leaking valve cover gaskets and oil cap stopped spewing till I could renew them.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is offline   Reply With Quote Quick reply to this message
In order to be able to post messages on the forums, you must first register.
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. is not in any way associated with Jeep or the Chrysler Corp.
