Blinker comes on when I push on the brakes. - JeepForum.com
post #1 of 24 Old 04-30-2008, 03:38 PM Thread Starter
Alan77
I have a 1990 JEEP YJ. When I press on the brakes the right front turn signal light comes on. Has anyone or everyone had this problem? What is the fix for this problem. I have tried a new ground wire and a new turn signal switch but the right front light still comes on when the brake lights come on.
Alan77 is offline
post #2 of 24 Old 04-30-2008, 03:45 PM
pat8942
pat8942's Avatar
Does this only happen with the lights on?
Did you check the socket for the side front marker light?
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #3 of 24 Old 04-30-2008, 04:40 PM
Russ_93YJ
The same problem just started for me last night! I installed a new winch but that was a direct hook up to the battery. WTF?
Gas first... Question it later!
Russ_93YJ is offline
post #4 of 24 Old 04-30-2008, 04:41 PM
xeroid81
Do your turn signals work normally?
xeroid81 is offline
post #5 of 24 Old 04-30-2008, 05:21 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I would check the bulbs and connection/ground wires to all the right side lights. INCLUDING the rear tail light. You would be surprised as to what those stupid tail light housings can do to your electrical system. The bolts that mount the housing to the tub ARE the ground.
Also, the rear tail light bulb is a dual filament bulb that is for the brake lights and turn signal. You could have a crossed fillament/bad bulb in the rear.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #6 of 24 Old 04-30-2008, 07:50 PM
xeroid81
That's exactly where I was going to. Any short in the flashers or bulbs can do wonders on your lighting systems. I believe if the bulb is crossed your flasher doesn't work on that side.
xeroid81 is offline
post #7 of 24 Old 04-30-2008, 11:52 PM Thread Starter
Alan77
All of my lights are working normally. They flash when I turn on the turn signals. They come on when I turn on the clearance lights and they are on when I turn on the headlights. The blinker light does come on when the other lights are on. All of my turn signals (front and rear) are working properly. It is just acting like a brake light on the front when I press on the brakes. I checked the socket for the bulb and it seems fine. I ran a new ground wire from the back of the light socket to a known good ground and I still have the same problem. I will check out the rear tail light housing's tomorrow.
Alan77 is offline
post #8 of 24 Old 05-01-2008, 10:37 AM
YJ_Dan
Left Directional Stays on
I have a 90 YJ and my left directional just stays on when I signal left turn. I guess I'll change the bulbs and check the wires.
YJ_Dan is offline
post #9 of 24 Old 05-01-2008, 10:45 AM
rustywrangler
That is your flasher gone bad. Up on the top of the under dash fuse block.
post #10 of 24 Old 05-01-2008, 03:43 PM
Blazin Den
my old xj had this problem and it happened to be a bad bulb in the rear tail lights. It was was i just changed a week before to, so if you put in bulb lately just double check it. Rear blown rear bulbs can cause the dash lights and turn signals to flash on when you hit the brakes.
95 White YJ 2.5L/AX-5 Stock on 31s. Ground Pounder Fab (BESRK) Front Bumper, Herculined Interior, Windshield/Front Bumper Mounted Lights, Uniden PRO 520XL Cb,Hidden Hitch Trailer Hitch, Bestop Supertop, Modified CJ7 Hardtop and CJ7 Twist Handle Full Doors (winter)
Blazin Den is offline
post #11 of 24 Old 05-01-2008, 11:03 PM Thread Starter
Alan77
Here is what I have done so far.
I have replaced ALL the bulbs, front and rear.
I have replaced both flashers, turn signal and emergency.
I have replaced the turn signal switch. That fixed my horn that wasn't working.
I have run new ground wires to the rear tail lights.
I have run a new ground wire to the front blinker that is giving me problems.
So far nothing has changed. My right front blinker still comes on when I hit the brake pedal. All my lights are working correctly except for the problem with the right front blinker coming on when I hit the brakes. Any other ideas?
Alan77 is offline
post #12 of 24 Old 05-01-2008, 11:11 PM
Barrio
id re-wired the whole thing if all else fails.
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline
post #13 of 24 Old 05-02-2008, 07:43 AM
pat8942
pat8942's Avatar
Have you inspected the condition of the front side marker light socket?
pat8942 is offline
post #14 of 24 Old 05-02-2008, 07:48 AM
Brokagain
It's because you failed to put corner protection on your jeep and bashing the corner has mashed your wires together in the corner. Reach up in the corner and check it out. Also, those square, factory tail lights corrode easily. I'm batting you bashed the wires. Based on past experience.
Brokagain is offline
post #15 of 24 Old 05-03-2008, 09:35 PM Thread Starter
Alan77
Today I inspected the condition of both side marker sockets. They both appear to be in good condition and they both work. I also inspected both rear corners to see if they had been smashed in and both rear corners are in great shape (never been wrecked).
I guess all that is left for me to do is to re wire my right fron turn signal and see if that fixes the problem.
Alan77 is offline
Blinker Click intermittent when the blinker is not engaged. ActionJackson00 TJ Wrangler Technical Forum 3 07-11-2009 06:53 PM
Left dash blinker on when using brakes J-Mox TJ Wrangler Technical Forum 5 07-01-2009 08:58 PM
left blinker/brakes issue solved (for now) XD40TJ TJ Wrangler Technical Forum 3 01-25-2007 04:50 PM
Push my brakes... lights come on? AlaskanYJ YJ Wrangler Technical Forum 3 11-21-2006 08:10 AM
Clutch easy to push one day, hard to push the next 92 RED YJ IN NJ TJ Wrangler Technical Forum 1 02-24-2004 07:57 PM
