Quantcast Bleeding YJ Slave Cylinder - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Bleeding YJ Slave Cylinder
Spartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-RoadBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 06-02-2009, 10:33 AM   #1
F1504x2
I asked this question before but can not find a bleeder screw. I have a 95 YJ with a 2.5L 5 speed. Looks like the Slave Cylinder is located on the outside of the trans.
I need to bleed this.
Thanks
F1504x2 is offline   Reply With Quote
Old 06-02-2009, 11:10 AM   #2
Opihi59
from here it gets rough
Opihi59's Avatar
Should have a bleeder in the top of the external slave, like this:
I believe it takes a 4 mm allen. You don't have to take it all the way out, just need to pump pedal, hold pedal down, then bleed-retighten then release clutch pedal and repeat. Takes a buddy.
Hope this helps.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://www2.hawaii.edu/~cbird/Opihi/descrip.htm
My Boy Scout Troop site: http://t-304.blogspot.com/
Something bad happened to my photobucket account (..it was my fault...)and all my pictures went blank. I am committed to editing all my writeups and posts to put the photos back in. Let me know if you find a post that needs revision and I will do that one ASAP Currently I believe I have all the critical ones done.
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Opihi59 is offline   Reply With Quote
Old 06-02-2009, 11:35 AM   #3
F1504x2
That should, if you made it any easier you would do it for me.
I was looking for a brake cylinder bleeder.
Thanks
Old 06-02-2009, 11:40 AM   #4
johnroot01
be careful though. if its an original part you might strip it like i did (rust). i had had to replace it, only about 17 bucks at advance auto.
95 YJ: 4" RC, 1" booms, 1" BL, 33x13.50x15 SS TSLs, 15" RCX steelies, minus sway and trac bars
ONLY IN A
|_Jeep_|
([ ]lllllll[ ])
johnroot01 is offline   Reply With Quote
Old 06-02-2009, 11:45 AM   #5
F1504x2
Sounds good, thanks. A lease it's external, not like my Ford where the trans needs to be pulled.
Also i see your in the Army, THANKS!!
Glock Forum
