Bleeding my clutch - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Bleeding my clutch
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTHE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 06-28-2014, 03:36 PM   #1
flojeepfreak90
Bleeding my clutch
Does anyone have a link, video or step by step instructions on how to bleed a 1990 2.5l jeep wranglers clutch??
flojeepfreak90 is offline   Reply With Quote
Unread 06-28-2014, 03:57 PM   #2
roadyrob
1987 YJ Wrangler
just open the bleeder till you get a steady drip, keep the master full, let it drip for 4 or 5 minutes, close the bleeder and your done.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline   Reply With Quote
Unread 06-29-2014, 12:01 PM   #3
Opihi59
from here it gets rough
Opihi59's Avatar
You may find you have to pump/bleed similar to bleeding brakes. Have someone pump the pedal a few times, hold it down while you crack the bleeder. Then tighten bleeder, have them release pedal, then pump again, etc until you get a "good pedal." This has always been my most reliable method of bleeding clutch hydraulic systems. And brake hydraulics as well. Good luck.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://kamfamily.wordpress.com/2009/...waiian-limpet/
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline   Reply With Quote
