Bleeding hydraulic clutch - JeepForum.com
post #1 of 3 Old 11-24-2011, 06:54 PM Thread Starter
glebo
ok, folks. Me again. No I don't have manual yet. But I will get one tomorrow..Speaking of which, whats the best one to get, Clymers or Chiltons, which one??
Sometimes the manual is not as good as "back yard mechanic" ways.
I used the search function, but it didn't actually give me what I wanted to know.
To bleed the clutch, do you do it like ya bleed the brakes, or is it better to "reverse" bleed it? Meaning, forcing fluid up the bleeder valve up to the the MC?? (with the cover off)??
Hope ya didn't eat to much...like me
Happy Thanksgiving...let the wheels roll..
glebo is offline
post #2 of 3 Old 11-24-2011, 10:59 PM
Leans93
She's my density...
Leans93's Avatar
You should fill out your profile so we know what transmission you have. I am assuming a manual transmission with an internal slave cylinder. Coming out of the back of your bellhousing should be two metal tubes, one going to the master and another that is the bleeder. Unscrew the bleeder valve and pump the clutch until there are no more bubbles. Pump a few times and then hold it to the floor and repeat this. Once there are no more bubbles close the bleeder and you're done. Also keep the master fluid filled up as it will drain some during this process.
The BEST manual to get is the Jeep FSM. These can be found online in electronic form or you can purchase one on ebay or the like. Any of the Chilton or Hanes will work just fine for most things though. I have a Hanes manual and the FSM.
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
post #3 of 3 Old 11-25-2011, 06:56 AM Thread Starter
glebo
Thanks L93, Yeah, the tube and bleeder are there in the bellhousing, that is correct. As far as tranny..I guess I gotta get underneath with a notepad and write down info to put in my profile...I suppose it would help knowing what type of tranny/xnsfer/motor I'm dealing with.
Thanks.
Off to autozone to get some fluid.
How this all came about..the clutch friction zone is very close to the floor, I'd guess around 3-4" (new clutch and PP were done not to long ago) and I get a "thunk" sometimes while shifting, (sounds like coming from tranny area) or even going over bumps on the hiway.
We checked and tightened some exhaust brackets, which the caty was sort of bumping the skid plate.
I've checked all tranny, motor, and xnsfer mounts, U-joints and they're all good.
I hope it's nothing internal, as the seller (who I trust) said all were gone through when he had the motor rebuilt...less that 3K ago..
I guess I'll just live with it until something explodes, or falls apart...
Thanks again for the help. Along with fluid, I'm also gonna get a manual...so I can RTFM..
glebo is offline
what is the advanatage of a hydraulic clutch over a cable clutch Slick101 TJ Wrangler Technical Forum 3 09-04-2009 11:07 AM
Clutch issue / bleeding clutch. Dravintoad TJ Wrangler Technical Forum 7 11-12-2007 11:50 AM
hydraulic clutch bleeding TJjeepangel TJ Wrangler Technical Forum 4 01-14-2005 10:47 PM
NEED HELP w/ hydraulic clutch bleeding!!!! Bret-o YJ Wrangler Technical Forum 6 01-01-2003 07:36 PM
Hydraulic clutch bleeding powjunkie YJ Wrangler Technical Forum 2 10-27-2001 09:08 AM
