Bleeding external clutch slave - JeepForum.com
post #1 of 2 Old 10-25-2011, 10:38 AM Thread Starter
thebeast64
How can I do this? I've got one of the slaves without the bleeder valve. Can I reverse bleed it by pumping the slave rod causing the fluid to go back up to the reservoir?
thebeast64 is offline
post #2 of 2 Old 10-25-2011, 10:42 AM
SoK66
2009 JK Wrangler
Don't hold me to this because it's been awhile since I monkeyed with a YJ, but IIRC it will self-bleed as you cycle the pedal. A few have a little bleed screw on them, but the factory sold them as a matched set with the clutch master already filled & bled. You did have to cycle the pedal a few times to get them operational. If that won't work you can possibly just bled it at the lines.
SoK66 is offline
Converting to external clutch slave eglide72 YJ Wrangler Technical Forum 3 12-20-2010 07:16 PM
Clutch Slave Cylinder External Vici0usX TJ Wrangler Technical Forum 3 07-05-2009 04:32 AM
Bleeding clutch with external slave question supraman1990 YJ Wrangler Technical Forum 23 02-19-2008 05:19 AM
Bleeding an external slave AX-15 Richmond88yj YJ Wrangler Technical Forum 4 09-10-2006 06:13 PM
Internal vs. External Clutch Slave Tshark299 YJ Wrangler Technical Forum 2 03-30-2004 10:23 PM
