Bleeding Brakes...No Fluid Comes Out the Bleeder Screw - JeepForum.com
post #1 of 14 Old 01-11-2007, 04:22 PM Thread Starter
martells2
I just put on new pads, calipers, and rotors and am now trying to bleed the system. I have filled the resovoir back up and had a buddy pump it until the pedal got stiff. Then he held the pedal down and I loosened the front passenger side bleeder screw. Nothing was coming out so I removed the entire bleeder screw and no fluid comes out! What am I doing wrong here? Does the vehicle need to be on to do this? Could the banjo bolt be in wrong? I didn't see a torque spec for it so I just made it hand tight. Thanks!
martells2 is offline
post #2 of 14 Old 01-11-2007, 04:35 PM
drexelsteve
Well sounds like your using the proper technique. There's probably a blockage somewhere, i'd bet it's the caliper itself. Did any fluid come out when you cut loose the banjo bolt for the caliper?
13 Rubi
drexelsteve is offline
post #3 of 14 Old 01-11-2007, 04:38 PM Thread Starter
martells2
I just came back to the garage and noticed brake fluid on the bottom of the piece the banjo bolt goes through. Does that mean its not tight enough? How tight should these things be? Also, the calipers are brand new...what kind of blockage would it be?
post #4 of 14 Old 01-11-2007, 04:39 PM
rexmundi
Old and Obnoxious
rexmundi's Avatar
You may have to have your buddy pump the brakes quite a few times to get all the air out of the lines. Have him pump them up, open the bleeder valve when the peddle goes to the floor close the bleeder valve and have him pump them up again. Repeat this process until you get fluid. Do the furthest wheel from the master cylinder first. And be sure you keep the master cyl. full or you will just get air back in the lines.
rexmundi is offline
post #5 of 14 Old 01-11-2007, 04:45 PM
drexelsteve
banjo bolt should be good n tight, not sure the torque specs but should be way tighter than hand tight. Kinda like the oil drain plug...you just know when it's right. Didn't forget the copper washers between the banjo fitting and the caliper, right?
13 Rubi
post #6 of 14 Old 01-11-2007, 04:48 PM
drexelsteve
Just to clarify...pump up the brakes then hold the pedal down fairly hard, while holding the pedal cut the bleeder loose. Your assistants foot should go to the floor. When it's at the floor close the bleeder. Then pump up again, hold and cut loose the bleeder, again to the floor, close the bleeder, etc.. Should usually do that at least 3 times per wheel, checking the fluid level in the reservior inbetween each wheel.
13 Rubi
post #7 of 14 Old 01-11-2007, 05:30 PM Thread Starter
martells2
nope, one on each side of the banjo bolt
post #8 of 14 Old 01-11-2007, 06:53 PM
TSEJEEPERS
This may sound like a stupid question and I am not real sure you could even do it but the bleeder screw is at the top of the caliper right?
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #9 of 14 Old 01-11-2007, 07:05 PM Thread Starter
martells2
somewhat...you can't miss it. The banjo bolt hold the brake line to the caliper. Then the other two bolts bolt the caliper down. The remaining and smallest one is the bleeder. BTW, I finally got the brakes bled. Lets just say my buddy wasn't working at his full potential
post #10 of 14 Old 01-11-2007, 07:22 PM
ufatbastehd
Don't you have to replace an ring or seal when you remove the banjo bolts and replace calipers
ufatbastehd is offline
post #11 of 14 Old 01-11-2007, 07:29 PM Thread Starter
martells2
yeah, I said I put two new washers on either side of the banjo bolt...they come with the calipers.
post #12 of 14 Old 01-11-2007, 07:45 PM
NEPhillyJeep
NEPhillyJeep's Avatar
Any luck?
How old is the fluid in your brake system? I had a buddy of mine that never had changed his fluid in years...well to make a long story short he had a blockage at the brake proportioner that distributes fluid to all the system(front and back, left and right) Other then that when you did change out the calibor how much fluid came out... you may just have a lot of air to bleed out.
NEPhillyJeep is offline
post #13 of 14 Old 01-11-2007, 07:46 PM Thread Starter
martells2
I said I got it fixed a few posts up
post #14 of 14 Old 01-11-2007, 09:00 PM
drexelsteve
well you don't have to be smug about it
13 Rubi
Bleeding brakes after re 3.5 sf(bleeder valve on FDS is stripped) Killedbybob TJ Wrangler Technical Forum 2 10-07-2007 03:49 PM
WTF Clutch Bleeder Screw RANGER_DANGER YJ Wrangler Technical Forum 1 09-01-2007 06:54 PM
Is a brake bleeder wrench necessary when bleeding brakes? blacktjsport TJ Wrangler Technical Forum 6 06-26-2007 07:11 PM
clutch bleeder screw Mumachog YJ Wrangler Technical Forum 8 11-26-2006 10:28 AM
clutch bleeder screw bananamane YJ Wrangler Technical Forum 1 11-12-2003 02:59 PM
