Blazer blower motor mod fail! - JeepForum.com
post #1 of 11 Old 06-23-2013, 09:13 PM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
I needed to replace my heater core so I figured it's a good time to do the blazer motor mod. All went ok till I turned on the heater blower. It will barely run on low fan speed and eventually come to a complete stop. On med and high it runs faster but makes all kinds of noises. It randomly speeds up then slows down and makes clicking noises.
Almost seems like the resistor is not matched for the larger motor.
Any ideas what might be wrong here?
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #2 of 11 Old 06-23-2013, 10:00 PM
DirtKar
Maximum Effort
DirtKar's Avatar
I'm not familiar with the Blazer mod so I'll stick with troubleshooting 101 until someone else steps in. Did you verify that the donor blower was in good working condition? Does it spin solid with a full 12v applied?
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #3 of 11 Old 06-23-2013, 10:40 PM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
It is a brand new motor from AZ.
post #4 of 11 Old 06-23-2013, 11:52 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
That may be your problem.
Anticanman is offline
post #5 of 11 Old 06-23-2013, 11:55 PM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
I meant to say it came from Advance Auto....is that just as bad?
post #6 of 11 Old 06-24-2013, 12:09 AM
packdog
Direct to battery
Like DirtKar hinted at -- apply a full 12 volts to the motor. Unplug the motor and hook some test leads from the battery to it.
If it works, then you might want to research what size resistor is in your jeep and what size is in a Blazer.
packdog is offline
post #7 of 11 Old 06-24-2013, 12:56 AM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
Thanks for the info...I will do that. There is only one plug with one wire going to the motor...How does it ground?
post #8 of 11 Old 06-24-2013, 03:32 AM
jsawduste
2006 YJ Wrangler
through the mounting frame.
jsawduste is offline
post #9 of 11 Old 06-24-2013, 05:24 AM Thread Starter
mudsweatNgearz
1987 YJ Wrangler
Great so I will test it tonight when I get home from work. If I give it a full 12 volts that should be like fan high speed....right?
post #10 of 11 Old 06-24-2013, 07:05 AM
jsawduste
2006 YJ Wrangler
Yup
post #11 of 11 Old 06-24-2013, 09:44 AM
Reno72
If I remember correctly some of the motors have a motor spindle that sticks out a little to far. Could the fan be rubbing the housing? This would explain the stalling at less power and noise at higher.
Reno72 is offline
