Dude check www.windrockoffroad.com
If you can't find it one the site email them, they'll respond within 24hrs and let you know if they have it and also a price.
They have prices = to or lower than quadratec most of the time, plus they have a bonus cash thing where you can use it to buy parts on their site. I use'em all the time. :thumbsup: :thumbsup:
$635 is an insane price to charge for a small lift kit that only includes 4 springs, u bolts, and new center pins. There has got to be a cheaper/better way.
I found a nice 1.5" lift by Black Diamond on www.acmejeepparts.com or you can click HERE. I like there pricing and have a large range of items. Hope that this helps, and the lift is $452.95. It comes with more then the springs.
I dont plan on going too big. thinkin bout 1.5" suspension, 3/8" boomerangs, and 1" bl. I want to keep a fairly low cog, and build a capable huntin/fishin rig, maybe a loker in the front eventually.
I got a Superlift 1.5 for the same reason - low COG. JC Whitney had a good deal going for awhile - 20% off. I believe Superlift now owns Black Diamond, but I don't know how much the parts interchange. Some things about the Superlift that I'm not wild about:
1) Had degree shims on the front springs, nothing but a transfer case drop for the rear. Never heard of that combo before, but it seems to work. Runs straighter down the road, and no vibration.
2) Front springs moved the front axle rearward about 3/4 inch or so. Rear springs moved the rear axle forward about 3/4 inch or so. My wheelbase is now 1 1/2 - 2 inches shorter than before. That plus a slightly stiffer spring rate makes for a rough ride. Wheels are not centered in the wheelwells like before. Rear is especially obnoxious because the factory flare sweeps back farther in front than in the back, so the tire is just off the front of the flare but has a few inches to the back of the flare.
3) Best thing - I haven't bottomed out on the rubber bumpstops yet! From the looks of the mud, they haven't touched since installation in October. My factory springs had a shiney clean spot from regular contact with the bumpstops.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
