Bl/YL Wire - JeepForum.com
post #1 of 9 Old 09-05-2011, 02:50 PM Thread Starter
sbs1794
Bl/YL Wire
while washing my yj one of my wires burnt up. It is a Bl/YL wire that runs in a harness along the drivers side of the car, all the way to the back. It is grounded right to the left of where your knee would be if you were sitting in the car. Im not sure how this happened, a tiny bit of a pink wire (which goes to the dome light in the hardtop) was also burnt up. Can anyone tell me what this bl/yl wire is? It is an 89 yj. Thanks!
sbs1794 is offline
post #2 of 9 Old 09-05-2011, 02:55 PM
tdewit
Desciption by wire color is hard, becuse it seems that the manu used different colors on a daily basis. The referred wire could be either the wiper motor or window heater if it does not go down the hole in the back of the drivers side to the lights. Could also be the wired going to the seat belt warning light.
tdewit is offline
post #3 of 9 Old 09-05-2011, 04:04 PM Thread Starter
sbs1794
it does go down into the hole to the lights, but all the lights still work fine, also it is still grounded even though it is disconnected from the ground, so it has to be grounded somewhere else. Maybe a body to frame ground wire? any thoughts?
sbs1794 is offline
post #4 of 9 Old 09-06-2011, 09:29 AM
Que89YJ
Fuel pump ground wire to the brake release bracket.
Que89YJ is offline
post #5 of 9 Old 09-06-2011, 10:56 AM
notmyj
Please fill out your profile. It may seem like a waste as its not abig deal on many forums but when you come here and ask a question about your jeep, the first thing most of us do is look at your profile to see what you have done to what ever jeep you own. Be specific as possible.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #6 of 9 Old 09-06-2011, 11:09 AM Thread Starter
sbs1794
the fuel pump still functions properly.
sbs1794 is offline
post #7 of 9 Old 09-06-2011, 11:11 AM Thread Starter
sbs1794
my bad it is actually a BK/YL wire. Any thoughts?
sbs1794 is offline
post #8 of 9 Old 09-06-2011, 01:52 PM
Que89YJ
Que89YJ is offline
post #9 of 9 Old 09-06-2011, 06:57 PM Thread Starter
sbs1794
one of those threads, the middle one, someone posted that the Bk/Yl wire is for running lights, but with it disconnected I still have running lights.
sbs1794 is offline
black , electrical , problem , wire , wiring
2 wire LEDs to 3 wire conversion (write up) zachjf TJ Wrangler Technical Forum 149 04-17-2017 11:57 AM
Anyone ever mastered the 3 wire turn signal rewired to the 2 wire LED Rippers TJ Wrangler Technical Forum 28 06-08-2016 01:29 AM
speed sensor wire and reverse wire for aftermarket navigation system Stacydmcc JK Wrangler Technical Forum 1 11-06-2009 03:07 PM
battery wire harness green wire? brinoff YJ Wrangler Technical Forum 4 03-07-2009 04:25 PM
95 YJ--Which wire is the crank(start)wire?? jnkyrdg04 YJ Wrangler Technical Forum 0 03-09-2007 01:27 PM
