bilstein 5100 and trailmaster - JeepForum.com
post #1 of 4 Old 11-09-2011, 11:14 PM Thread Starter
BIGJoe29
hey guys im getting a 3in trailmaster lift for my 1990 yj. im planning on getting some bilstein 5100's. i was just wondering if they would fit. do i need to extend bump stops? should i get wheel spacers? im keeping stock rims and getting some 31x10.5's. thnx
2.5L w/ AX-5, NP231J w/ Rugged Ridge SYE and XJ front driveshaft, open D30 and D35 w/ 4.10 ratio, stock JK 18in wheels w/ Spydertrax 1.25in spacers and 32in toyo at, 2.5in RC lift with .5in shackles(BESRK), rear TJ flares. 8.8 rebuild soon
BIGJoe29 is offline
post #2 of 4 Old 11-10-2011, 12:51 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
There are a thousand ways to run your proposed set up. Any shocks would technically work if you had the right length shock towers. (following?) just adjust the steering stops to avoid rubbing on the leaf springs and your tires will last a lot longer. Wheel spacers? Better off with different rims. You'll maybe need to extend your bump stops if you do some trail riding and flex a bit. With your track and swaybars on, I wouldn't worry about bumpstops, you'll never need them.
Luck Favours The Prepared
Anticanman is offline
post #3 of 4 Old 11-10-2011, 08:24 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
I agree with Anti. As for shock length and 'do you need longer bump stops', it's easy to figure after you get the lift on. Here is a link to an exact post I wrote a couple days ago for someone else.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #4 of 4 Old 11-10-2011, 08:51 AM
Louie4
"You pass butter"
Louie4's Avatar
I have a 3.5" Black Diamond, well 3" now but I got some extended bumpstops a few weeks ago but I'm waiting on my buddy to drop them off. I know I need some because my drag link is hitting the tie rod. That's what is limiting my stuff on the drivers side. Plus the springs are flattening and nearly inverting. I've wheeled like that for years but I'm starting to take care of the little things. Hopefully it will keep the steering from hitting itself.
As for shocks you'll just need to measure after the lift like Don and Anti mentioned.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
bilstein , jeep , suspension , YJ
Bilstein 5100 or Old Man Emu? telkins88 TJ Wrangler Technical Forum 25 05-29-2012 10:50 AM
Trailmaster 3in lift w/Bilstein 5100 shocks BIGJoe29 YJ Wrangler Technical Forum 9 10-05-2011 11:57 PM
Bilstein 5100 ? Swelbo1 TJ Wrangler Technical Forum 5 06-13-2011 02:47 PM
Bilstein 5100 or OME Gumby1 TJ Wrangler Technical Forum 10 10-23-2010 07:54 PM
Bilstein 5100 are POS, what's next? GrimJeeper91 YJ Wrangler Technical Forum 3 08-02-2009 11:15 AM
