Bigger Radiator? - JeepForum.com
post #1 of 134 Old 08-25-2014, 07:46 PM Thread Starter
Louie4
Bigger Radiator?
I did some searching but didn't find an exact answer and wanted opinions anyway. I took my jeep down to Savannah this weekend from Raleigh where it was mainly interstate. I was going 70-75 mph consistently and my Taurus fan was running the entire time and I had to keep the defrost on low to keep the engine from running over 230F. If I went over 65 mph the temp would creep up to 230 and if I didn't turn the defrost on it seemed to keep creeping. On the way back I hooked the high speed circuit to the low temp switch (Beck-Arnley switch) to keep the high speed on all the time but still the same result.
Now the background info. I have an M8274 sitting on my bumper blocking all that air. I also run a single core Autozone radiator. I installed a Taurus two speed fan which is controlled by a Beck-Arnley temp. switch plumbed into the top radiator hose. My question is should I look into a 2 or 3 core all metal radiator for added capacity or try something else to help keep the engine cool?
I might also add that my gas tank was high pressurized after I replaced my filler and vent hose. It wasn't on the way back and today I saw the side of the tank had gas on it so I may have blown the top seal for the sending unit.
On top of all that, my new external slave clutch was fading right when I left Savannah.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #2 of 134 Old 08-25-2014, 07:56 PM
langwilliams
has anyone tried those hi tech coolant replacements to lower temps? I think water wetter claims you'll run at least 10 degrees cooler by adding it to the coolant, an there's stuff that replaces all the coolant.
langwilliams is offline
post #3 of 134 Old 08-25-2014, 08:09 PM
Reno72
Not a good trip, sorry to hear. I'm running the Champion 3 row and notice the difference, that said this will be the first season in the desert so I'll know more when I do some slow speed crawling out there. What I noticed is as the thermostat opens my temp gauge drops quick and slowly builds to running temp. I feel the extra capacity and more rows allow the tank to cool the coolent more efficiently.
Reno72 is offline
post #4 of 134 Old 08-25-2014, 10:27 PM
Mambo_Dave
Yes. I used Water Wetter back when it first came out - back then it came as a pink solid, not a liquid, lol. (I buy it now in liquid form.) I also had an after-market water temperature gauge that was much more sensitive than the stock ones. Water Wetter certainly works. It seems to work really well at releasing heat once the airflow increases.
Will it work with a single-core radiator that doesn't seem to be getting enough air? Perhaps not.
Mambo_Dave is offline
post #5 of 134 Old 08-26-2014, 03:32 AM
Drednot
The winch blocking the airflow may be hurting your cooling capacity. The Taurus fan wasn't doing didly at 70 mph, except possibly blocking more airflow. How old is your water pump, and thermostat? A rotten impeller, or thermostat partially closed, restrictions from that fan switch being in the upper hose, collapsing lower radiator hose or your radiator is getting crusty inside. Single row radiators are fine if you don't have something blocking airflow, or restricting coolant flow. If your rad is not new, and you need to replace it anyhow, get multiple cores. If its recently new, going to multiple cores will just mask the real problem.
Water wetter does work, but is just a bandaid in this instance.
It's really made for something that needs every ounce of cooling capacity for competition, like a baja racer. Your vehicles cooling system should be more than enough if its all working properly.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #6 of 134 Old 08-26-2014, 03:55 AM Thread Starter
Louie4
It runs cool when crawling and driving around town and I run a plain 195F thermostat.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #7 of 134 Old 08-26-2014, 04:50 AM
superj
need a bigger radiator or the radiator cleaned then. the winch is probably blocking a lot of air so try riding with out it some day
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #8 of 134 Old 08-26-2014, 05:54 AM
Drednot
Yeah, you got high speed airflow, or coolant flow issues.
Read your profile. Lots of lift and weight, big tires, not a whole lot of gearing. You got lots of heat to dissipate at 70-75 mph. I would try de-mounting the winch and see if that makes a difference.
Got pics of the front of your grille, and the back of your radiator?
Also, how old is the stuff that moves or restricts your coolant flow?
Does your lower hose still have the spring inside?
https://www.youtube.com/watch?v=fJjxD0Ha-mw
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #9 of 134 Old 08-26-2014, 05:07 PM
Reno72
Have you looked at the poison spyder hood louvers? They allow the hot air to go out the hood and allow a better flow of air.
Reno72 is offline
post #10 of 134 Old 08-26-2014, 06:25 PM
Drednot
Hood louvres is always a good idea. Mopar sells some that open and close automatically and seal out water for around $20 each
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #11 of 134 Old 08-26-2014, 06:34 PM Thread Starter
Louie4
Here is a grille pic. I'll reply to all the comments shortly.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #12 of 134 Old 08-26-2014, 06:44 PM Thread Starter
Louie4
I've had many radiators. This is the 3rd Autozone replacement and I know it's clean both inside and out. The M8274 I got this past spring and my engine did OK without it but the temps would still get a little over 215 or so on the highway in the summer. But then again, I didn't make a 5.5 hour trip in at highway speeds in the summer without it that I can remember. I mainly rode in the fall and spring.
I have 33's the 4.0L and 4.10's which is putting me not far from stock in terms of rpm. I run about 2700 rpm's going around 70 mph on relatively flat roads.
The grille pic is posted above. The radiator is very clean mainly because it's fairly new. The waterpump is a new one I got that fits a Cherokee. It has a flat flange for the waterpump pulley giving me more fan clearance. The thermostat is new and has a small bleeder valve. The Taurus fan still works good. I know for a fact removing the winch will make it run cooler but I would like to keep it on and try to add cooling capacity. Also, I put a stainless steel welding rod that I curled up in the lower radiator hose a while back to make sure it wasn't collapsing under high rpm's.
Yes I have. I will have to see if I need to relocate my Hi-Lift jack because it is most likely in the way but it's definitely an option.
I may explore this idea if I can keep the Hi-Lift where it is for now.
I think the real question I should ask is, will getting a higher capacity radiator with more cores give me the extra cooling I need? As said before, I have the lifetime warranty Autozone single core special with plastic caps.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #13 of 134 Old 08-26-2014, 07:15 PM
Delawdude
Yes--also, in order to free up some air movement real estate, others have also relocated the winch control box to under the hood. It's not much, but it helps.
Delawdude is offline
post #14 of 134 Old 08-26-2014, 07:36 PM Thread Starter
Louie4
I think that will be the next step once I find a welding shop that can make me some leads. I have some 1/0 welding wire as of now and it works great.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #15 of 134 Old 08-26-2014, 08:59 PM
Dake
Dake's Avatar
I have the champion 3 row as well and it keep it cool. Your winch cover a lot more than mine. I also have good heat in the winter.
Waiting on my Rough Country lift to sag!
Dake is offline
