Bigger oil filter for the 4.0 - JeepForum.com
post #1 of 6 Old 01-21-2010, 04:16 PM Thread Starter
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
If this has been posted before I didn't see it but here goes.
My son and I decided to change oil in our two cars. I have the '95 YJ 4.0 and he just bought a ’93 Mustang 5.0. So off we got to the NAPA store to buy our oil and filters. The NAPA dude drops the two filters on the counter and I notice that they look like they are the same diameter. So we open up the two filters and I’ll be damned if they are identical except the Mustang oil filter is almost 1 ˝” taller. The Jeep filter number is a NAPA Pro Select 21085. The Mustang oil filter number is a NAPA Pro Select 21515.
So he pulls the specs for us and they have the identical mating faces so I decide to go with the Mustang filter for my 4.0. It fits just fine and here is where my intuition paid off, I think.
If my calkelashuns are right, the volume of the Jeep filter is 38.9272”. The Mustang filter has 54.4771” of volume. That’s 15.5499” more volume than the Jeep filter. I just added a bit more oil to the base for the additional volume of oil filter.
I figure that more filter material can't be bad now, can it.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #2 of 6 Old 01-21-2010, 04:33 PM
Fhajad
Max shows that he used a bigger one in his write up.
I don't quite see the purpose but I might do it if the price isn't too much higher.
Fhajad is offline
post #3 of 6 Old 01-21-2010, 04:34 PM
jbolty
jbolty's Avatar
Good info, but there is more to a filter than fitting. I looked up the specs on wix filters out of curiosity. Similar but the specs are a little different. Close enough for me though.
mustang
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper/Glass
Height: 5.178
Outer Diameter: 3.660
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Ends: Metal
Beta Ratio: 2/20=13/23
Burst Pressure-PSI: 290
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
jeep
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.790
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
Beta Ratio: 2/20=15/28
Gasket Diameters
jbolty is offline
post #4 of 6 Old 01-21-2010, 05:06 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
They're actually cheaper than the Mopar MO 090 that is called out.
Yep, I use the Motorcraft brand FL-1A filters from Wal-Mart.
Details here.
http://www.jeepforum.com/forum/f12/b...change-865490/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 6 Old 01-21-2010, 07:48 PM
4.7stroker
I use the Napa Gold version of the FL-1A filter.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #6 of 6 Old 01-21-2010, 08:09 PM
bob082484
Ive been runnnin the bigger filters for years now. Ive found out that the 93 mustang with the 5.0 (It'll probably work with any 5.0) filter will work on the 4.0 and the 2.5. There is a writeup somewhere on retrofitting oil filters. Purolator Pure One #30001 and the fram tough gaurd #tg8 or any fram size 8 will work.
bob082484 is offline
Bigger Lift means Bigger Problems?? Jeep Kid TJ Wrangler Technical Forum 1 03-08-2008 03:41 PM
Bigger oil filter works for 4.0 Cobra Jeep YJ Wrangler Technical Forum 10 06-08-2006 07:14 PM
Bigger oil filter on your 2.5L YJ!!! 19OlllllllO41 YJ Wrangler Technical Forum 8 06-02-2006 08:04 AM
Bigger oil filter? VegasJeep TJ Wrangler Technical Forum 12 12-22-2005 11:32 AM
Bigger oil filter for the 4.0 six? nitecop TJ Wrangler Technical Forum 6 07-13-2005 05:51 PM
