big yj shocks question? - JeepForum.com
post #1 of 7 Old 06-22-2010, 01:48 PM Thread Starter
PinkJeep508
i have a 92 yj with a spring over and bout 3 inch lift springs, but im having a hard time finding shocks need help
thanks
JAKE
PinkJeep508 is offline
post #2 of 7 Old 06-22-2010, 02:03 PM
NateWithoutBeer
Jeep shock absorber application guide - Quadratec
Goes all the way up to 6" of lift. With a springover and 3" springs do you have more than that?
Originally Posted by offshore View Post
So I totalled my 2005 Unlimited about 3 weeks ago, and now that I could find something that I really wanted I decided to go with a YJ. I loved my 04, but I wanted a real jeep
NateWithoutBeer is offline
post #3 of 7 Old 06-22-2010, 02:11 PM
Louie4
Have you measure the distance from the mounting points at full flex and compression?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #4 of 7 Old 06-22-2010, 02:15 PM
monkeyhouse
Exactly, this is the best way to know what you need, nothing else will come close, great response!
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #5 of 7 Old 06-22-2010, 02:18 PM
notmyj
Decide what shock you want, then go to the manufacturer website and llok at the listings. The retailers don't list every shock made by a company, only the popular ones. The manufacturer will lust every shock they make and give length extended and compressed.
In order to get the right shocks, you will need to know what the measurments are between the shock mounts compressed and extended.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #6 of 7 Old 06-22-2010, 05:01 PM
highrolrcustoms
on the front disconnect the sway bar and take the sway bar mount/leaf spring plate and rotate it and use that as the lower shock mount....gives ya about 4" or 5" i think...thats what i had to do
as far as the rear goes....i had to just weld on new mounts on the axle
95 yj juggy, backhalfed, 3 link front with 16" fox dual rate remote resi coilovers, 4 link rear with 16" fox air shocks, Monster Stak 2 Speed transfer case 4.33:1, full width ford 78/79 dana 60hp front axle with 538 gears and full spool, ford sterling 10.25 full width rear axle with 538 gears welded and disc brake conversion, 42x15 swamper tsl's on 15x8 Allied wheels 3.5" backspacing with DIY beadlocks, High Steer with 1.5x.250 dom tubing, Full Hydro steering, custom cage, rci 2161a fuel cell ,smitty xrc 8 winch, cv driveshaft, jk motor mount lift, racing seats with simpson 5 point harnesses
"THE MORE YA PLAY WITH IT.....THE BIGGER IT GETS"
highrolrcustoms is offline
post #7 of 7 Old 06-22-2010, 06:38 PM
jeepinmichguy_
flex it, measure, call doetch tech, give them measurements and order.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
I have a question about shocks! YjMudder YJ Wrangler Technical Forum 9 03-04-2010 04:31 AM
Question on shocks CWD98TJ TJ Wrangler Technical Forum 2 11-16-2008 05:57 PM
Shocks Question likwufi TJ Wrangler Technical Forum 9 04-15-2008 02:42 PM
OME shocks question mic6 TJ Wrangler Technical Forum 4 01-25-2007 01:59 PM
Shocks Question farinspace TJ Wrangler Technical Forum 11 03-19-2005 07:51 PM
