Big Problems - JeepForum.com
post #1 of 5 Old 12-16-2001, 07:52 PM Thread Starter
shea324@aol.com
Big Problems
First off I gotta admit that I don't know much about engines. So heres my problem: When driving at most speeds while applying gas, i hear a sound like air being pushed through a small hole. But if i let off on the gas, the engine quiets down again. I am slowly loosing coolant (I don't think I have any leaks) and the exhaust constantly blows a thin white smoke.
I think that my head gasket is damaged, which would explain why I am loosing coolant right? and that could also explain the noise - which sounds like air being pushed through a small hole. Am I right so far?
If this is the case, does it need replacing? will it get worse? will it damage the engine? How hard is it to fix? What would it cost of I took it somewhere? and how hard is it to remove the head from the engine block?
Any help would be appreciated... Im screwed aren't I?
90' YJ Four Banger, 2" Lift, 31" Tires, Many Mods to come
shea324@aol.com is offline
post #2 of 5 Old 12-17-2001, 06:24 AM
glm 87 wrangler
sounds like a head gasket check your oil for water just pull the dipstick out and see if it looks milky or has a funny color.Being its a four cyl the cost of a head gasket and having the head milled should run you between
260.00 to 400.000 bucks.The reason i give this price is if you live in a big city most times you pay more than if you live in the sticks..Hope this helps.
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #3 of 5 Old 12-17-2001, 07:42 AM Thread Starter
shea324@aol.com
Thanks for the reply but $260 - $400? I got 2 quotes: $580 and $660!!! and the first one was just some guy with a shop down the street. #2 was a chrysler dealer. geez $260, I would give that and girlfriend for a night to get this prob fixed.
post #4 of 5 Old 12-17-2001, 09:34 AM
Big92Jeep
I'll do it for just the Girl Friend! Any pics?
~RýCK
Just kidding. You can get it down here locally in FL for around $300. So keep looking.
2008 Unlimited Rubicon
"The weather is here, I wish you were beautiful"
Big92Jeep is offline
post #5 of 5 Old 12-19-2001, 04:56 PM
IBjeepN4mud
Hey if you have tools you can do it your self. It's really not that hard. Just get a shop manual and it will show you step by step on doing this.
Unless if your like me, and don't have the time.
1st jeep 83 cj8 scrambler
2nd jeep 92 yj wrangler
3rd jeep 88 yj wrangler
4th jeep ??????????? Still looking
IBjeepN4mud is offline
LED Tails - problems problems problems! Zachs TJ Wrangler Technical Forum 5 07-20-2009 10:21 PM
94 2.5 still having problems HELP lckdrgn YJ Wrangler Technical Forum 16 03-16-2009 01:22 PM
D44 Gear Problems, shaft problems. lazerusrm TJ Wrangler Technical Forum 7 04-09-2008 05:29 PM
3in BL 4wd problems mike0110 TJ Wrangler Technical Forum 2 05-03-2007 06:33 PM
4WD vac problems... NEED HELP!!!! everyday-tan YJ Wrangler Technical Forum 1 09-18-2006 09:54 PM
