big problem...need help now!! - JeepForum.com
post #1 of 9 Old 01-30-2012, 06:21 PM Thread Starter
k-bar
Ok so I went to change out my fuel injectors to bigger ones(but they didn't fit). So I had to but my old ones back in....and my front 2 injectors just poor/shoot out gas whenever I turn my jeep on. So I pulled the fuel rail again and put it back in and same thing. I replaced all the o-rings also. The rail just kind of sits there until I but the bolts in. I tried pushing on the rail, but the fuel injectors didnt seem like they wanted to seat(if they are supposed to). idk what else to do!!! Help This is a 2.5l
k-bar is offline
post #2 of 9 Old 01-30-2012, 06:37 PM
Mark05059
grab some vaseline and lube up the orings...
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 9 Old 01-30-2012, 06:39 PM Thread Starter
k-bar
yeah I used some motor oil. I will try some vaseline and see how that goes.
k-bar is offline
post #4 of 9 Old 01-30-2012, 06:40 PM
Ripper3494
whatever you do dont try to start it like that, i blew up 2 engines because of a stuck open injector that just let fluid through
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #5 of 9 Old 01-30-2012, 06:42 PM Thread Starter
k-bar
well idk how to tell if it is stuck open. It only does it when it is running.
k-bar is offline
post #6 of 9 Old 01-30-2012, 06:44 PM
Ripper3494
hm... turn the key on with the injectors out, the fuel pump will prime for 2 seconds and if gas shoots out its stuck open
build thread:
RC vs BDS
post #7 of 9 Old 01-30-2012, 07:40 PM
Mark05059
I think he is saying that it shoots out where the rail attaches to the injector... not out of the injector nozzle itself.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #8 of 9 Old 01-30-2012, 07:46 PM
Ripper3494
oh, then i got nothin really, shove it in harder? lol
build thread:
RC vs BDS
post #9 of 9 Old 01-30-2012, 07:55 PM Thread Starter
k-bar
Well I am not quite sure where it was coming out of. I just knew the around the front 2 injectors. I didn't have any vaseline, but in the dermatology field(my work) Aquaphor is the next best thing and I had some. So I pulled the rail, lubed up the o-rings, and re-installed everything. Works fine now with no leak. Ripper I tried your trick and no leaks before I installed the rail. and thanks Mark for the lub info. Guess I should always keep some handy!
k-bar is offline
clutch problem ? Master / Slave Cylinder Problem rthompson48082 YJ Wrangler Technical Forum 34 11-30-2011 05:31 PM
Belt problem, blinker problem, and a random problem... Mike89db TJ Wrangler Technical Forum 10 12-14-2009 05:34 AM
brake pad problem, and front drive shaft problem bluejeep2088 TJ Wrangler Technical Forum 1 05-12-2008 09:34 AM
Brake Fluid problem or Jeep Drinking problem daledaniel TJ Wrangler Technical Forum 6 01-04-2008 09:11 PM
FINALLY! fixed idle problem and stalling problem Big-n-Broke-YJ YJ Wrangler Technical Forum 4 02-28-2006 07:50 PM
