Bfg km2.. - Page 2 - JeepForum.com
post #16 of 41 Old 03-31-2013, 09:55 AM
ssyj94
Sorry but it'll take 2 sets of x-terrians to match one set of km2s since they wear out so fast and come on mud grapplers... I bet thornbirds could be the only upgrade from there.
I ran km2s for a longtime in everything possible except deep sand and they hooked up well. On the street they were quiet, round and grabbed in the rain/snow. Only issue I found was a somewhat weak sidewall when aired down below 10psi. But any radial tire would have had the same issue. As far as not cleaning in mud a set with less than 50% tread was able to conquer this mud hole made up of motocross track slop.
https://www.youtube.com/watch?v=4KVQoK_SVcg
My build:
ssyj94 is offline
post #17 of 41 Old 03-31-2013, 10:00 AM
Noltz
YJ Wrangler
I've got KM2's as well. They work a lot better than the AT's that came off, off road. I got stuck a few times in muck where the bogger tired trucks didn't. I've only got ~8k on 'em on the street, where they live a happy life. Way quieter than the original MTs I had on my old Jeep.
Would buy again. Good compromise tire.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4½" & shackles, BFG 33's (sold)
Noltz is offline
post #18 of 41 Old 03-31-2013, 10:03 AM
SLADE
The Xterrains wore better (milage wise) than the KM2's did. The KM2's where also better maintained. The Xterrains just had more uneven wear from not being rotated properly (Directional tire)
Comparing Mud Grapplers to Thorbirds just shows your ignorance and lack of ability to inteligently discuss tires. I bet you read that on the enternet or heard your friends uncle didn't like them.
You hear this alot when KM2 owners mention short comings of the KM2. Sorry to break it to you, but not all Radial MT tires have weak sidewalls and not all Radial MT tires suck on wet, snowy, and icy roads like the KM2s do.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #19 of 41 Old 03-31-2013, 10:21 AM
SLADE
Nitto mud grapplers are some of the worst tires I have ever seen. Ever. I was side by side with a brand new rubicon and my km2's grabbed the rocks where his nittos forced him to lock the rear axle. Yes it was the same line and yes we were both running 35's.
I'm not making any claims for or against them on rocks.
I see more mud than rock. I'm not talking mud pits and swamps. They strugled on virgin wet soil. There is no comparison between the two. The Nitto's will walk through wet off camber areas where the KM2's had to rely on momentum to keep from sliding side ways. The Mud Grapplers will let go of chunks of mud at slow rolling speeds where the KM2's would need higher wheel speed and spinning tire/breaking traction.
The KM2's lack of sipes and squared tread blocks offer very little on wet, snowy, and icy roads. The Mud Grapplers do have sipes, the tread blocks very in size and shape and the alternating tread pattern does offer good wet, snowy, and icy road performance. I assume the alternating tread (side to side) is also responsible for them maintaining lateral traction.
After the miles I've put on them both I truelly hate the KM2.
The KM2's where by far smoother, quieter, and more comfortable on the street. I didn't buy an MT tire because I wanted a smooth quiet ride on the pavement though. I bought them because I needed an MT tire that performed well in the mud and offroad. The KM2's did not fullfill that need.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #20 of 41 Old 03-31-2013, 11:08 AM
rebelbowtie
You have to be a troll, I cannot take this post serious. I have ran Nitto Mud and Terra Grapplers and they both suck at nearly everything. They wear like soap and the Mud Grapplers require a lot of power to spin because they're so heavy.
rebelbowtie is offline
post #21 of 41 Old 03-31-2013, 11:15 AM
tjkj2002
2002 KJ Liberty
The KM2's run very short,if you want 33" tires gotta buy 35" KM2's,if you want 35" KM2's better buy 37 KM2's.
In colder weather they have zero traction on the rocks and even less with a little mud/snow mixed in.My buddy has them on his Jeep which is pretty much setup identical to my Jeep and he couldn't hang with my MT/R K's,even when he had both ARB's engaged and I stayed open/open.
tjkj2002 is offline
post #22 of 41 Old 03-31-2013, 11:19 AM
TrentYJ
My KM2's clean themselves so well that I regret taking my rear fender flares off. In florida here those things plow through the mud and the swampy areas but I could see how they may clog in some bama clay mud which probably any tire would do. As for wear, I've had the 35's on my DD YJ for 2 1/2 years and still have significant tread left. If you rotate them regularly, you'll have very low road noise too. I'm going to get em again when they wear out bc they feel like an all terrain on the road and behave like a swamper in the mud.
"Arguing over the internet is like running in the Special Olympics...Even if you win, you're still retarded."
-François-Marie Arouet
TrentYJ is offline
post #23 of 41 Old 03-31-2013, 11:55 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
34.5" for the 35" km2's. its hardly worth going to 37's which are actually 37" tall.
Luck Favours The Prepared
Anticanman is offline
post #24 of 41 Old 03-31-2013, 12:38 PM
tjkj2002
2002 KJ Liberty
Not even close.My buddies 35x12.50x15 KM2's on a 15x8 rim at 27psi are only 33.25" tall.
tjkj2002 is offline
post #25 of 41 Old 03-31-2013, 12:45 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I can measure mine when I get home. Psi is relative though, its gonna be way lower offroad and you are going to inflate or deflate based on the choice betwixt axle tube clearance or contact patch. It may be comfy at 27 psi (I run 26 more or less) but that isn't the recommended pressure for road use, just the adjustment for comfort. No tire is going to be the advertised height with the weight of the vehicle on it. However, I still believe its a good tire and despite the size grievance, I would buy another set.
Also I couldn't find a set in 37 12.50 for a 15" rim. Anyone got a link?
post #26 of 41 Old 03-31-2013, 01:07 PM
rebelbowtie
All BFG's are known to run short in certain sizes.
post #27 of 41 Old 03-31-2013, 01:14 PM
dillonjm
2013 WK
All MFGs vary, somewhat like how TVs do. FWIW, the websites of all the different tire MFGs list actual tire sizes for each size class.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #28 of 41 Old 03-31-2013, 01:19 PM
Cajun90YJ
I like mine, good road manners no problem cleaning them out they pull good but like everyone else said they run small. My 37's measure 35 1/4 and narrow. I could only find 37's in 17" wheels. You have to remember there will always be a compromise, good onroad manners will not be as great off-road. A km2 wont pull like a bogger but a bogger wont handle on road like a km2
Cajun90YJ is offline
post #29 of 41 Old 03-31-2013, 01:37 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Methinks I'm a little confused by this statement.
post #30 of 41 Old 03-31-2013, 01:53 PM
tjkj2002
2002 KJ Liberty
Max psi is 35 on the 35x12.50x15's.You don't need max psi unless your towing 15,000lbs otherwise you wearout the center tread and really have no traction.
tjkj2002 is offline
