Beware the 2" shackles - JeepForum.com
post #1 of 7 Old 07-12-2010, 04:37 PM Thread Starter
ryans93
I have encountered yet another serious problem. The po wanted a really cheap lift so I am stuck with buck toothed 2" shackles. Upon fixing another problem (the engine falling out) I noticed that the bracket that holds the front end of the rear leaf spring was just about cracked all the way through. This was about to cause some serious damage. So now I've got a pretty crummy welding job that is not going to last very long. So my question is, could having giant shackles cause this? Or was this more of a rust issue, because my frame is pretty rusted out. And can I get new mounts or would it be better to just get a new frame all together?
It should be fine as long as it was "gently" rolled...
1993 YJ 4.0L 5spd Manual. OME 2.5" with 3/4" M.O.R.E Shackles & 1"BL
Not to mention the body doesn't match the frame that doesn't match the engine...
ryans93 is offline
post #2 of 7 Old 07-12-2010, 05:35 PM
ZeroGravity
That's most likely due to rust.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #3 of 7 Old 07-12-2010, 05:36 PM
g4x4xgeoff
if your engine fell out, it's because of rust.
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #4 of 7 Old 07-12-2010, 05:39 PM
moonshinefuel
Post some pics of the frame. Its one of those things that images are important.
moonshinefuel is offline
post #5 of 7 Old 07-12-2010, 05:45 PM
94yjstocklook
sounds like, rust. long shackles mainly put more stress on the leaf springs.
94yjstocklook is offline
post #6 of 7 Old 07-12-2010, 06:16 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
That's like asking......"which candy bar caused me to have cavities"?
Serious rust + tall shackles = excellent formula for issues.
You are being vague & didn't post quality pics - so answering your solution question with a decent answer would be a guessing game at best.
Is that what you wish folks to do?
Joe Dillard is offline
post #7 of 7 Old 07-12-2010, 06:47 PM
Area.3.Fiftyone
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
Beware factory 18" Bridgestone tires mandalayjim JK Wrangler Technical Forum 9 04-23-2010 08:34 AM
jeep pics before and after rough country 2 1/2" lift and 1" boom shackles boaty1 YJ Wrangler Technical Forum 16 11-15-2008 06:03 PM
What shocks should I run? 4" springs, 1" boomerang shackles, 1" body lift Dwayne93YJ YJ Wrangler Technical Forum 3 06-02-2008 11:15 PM
4" RE/BDS vs. 2.5" OME Springs + 5/8" MORE Shackles + 1" Body and/or TJ Flares? KUJeeper82 YJ Wrangler Technical Forum 12 08-04-2007 08:45 PM
with 3" susp lift can i add 2" Bomerang shackles without mods to drvshaft yoke? ookxtreme YJ Wrangler Technical Forum 2 10-02-2004 08:47 AM
