A better locker for the Dana 35? - JeepForum.com
post #1 of 8 Old 01-23-2002, 07:06 PM Thread Starter
AndyMan569
I have a 93 wrangler with a rear Dana 35 with 4:56 gears and 36x14.50 Swampers, and over the past 2 years I have blown 2 Detroit limited slip locker Tru-Tracs. I am on a pretty tight budget and cant afford air lockers. Does anyone have any suggestions on a better alternative to the Detroit locker Tru-Trac??
PROJECT: 3/4 ton, NP205, TPI-V8, 91'YJ Wrangler
AndyMan569 is offline
post #2 of 8 Old 01-23-2002, 09:22 PM
osburn
osburn's Avatar
There's no such thing as a "limited slip locker". Stop using limited slips. They're not lockers. Try the Detroit no-spin, they're considered damn near indestructable. http://www.tractech.com/Products.htm#locking
Be advised no matter what locker you run, you're likely to have problems with a Dana 35 and 36" Swampers. Too much stress on that axle.
Matt Osburn
Score 1032
osburn is offline
post #3 of 8 Old 01-23-2002, 09:56 PM
RodeoRob
RodeoRob's Avatar
Originally posted by osburn:
There's no such thing as a "limited slip locker.
Oh really my Jeep friend? What about the new Electric lockers in development that when activated, are a full locker, and when off, are a helical gear limited slip? I believe Detriot's working on one as well as that Japanese company (name slips my mind).
Sorry, couldn't resist a chance to bust your chops!
Andy, if you do a lot of offroading, ditch the tru-trac and look at a real locker. no-spins are pretty bulletproof... but as osburn said, be forewarned, you're already stressing that D35 pretty far.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #4 of 8 Old 01-24-2002, 07:45 AM
GREGDOG95YJ
GREGDOG95YJ's Avatar
rodeorob the electric locker your thinking of is the one they will be using in the new rubicon edition wrangler. The name of the company is Tochigi Fuji Sanjyo. Eaton is also finalizing there design on an electric locker too.
Jason Gregory
95 yj Rio Grande 2.5L
31" BFG MUDS, 1"BL,2" homemade spring lift, 150W KC'S, KN Filter, both air restricters gone, track bars gone, quick discos, & high flow cat
"just like all addicts my need to satisfy my addiction far exceeds my wallet!!"
GREGDOG95YJ is offline
post #5 of 8 Old 01-24-2002, 06:31 PM Thread Starter
AndyMan569
Thanks Ya'll, I've been wanting to swap out the rear axle since the first time it broke a locker, but didn't have the cash or the time. So, I found a few decent priced Dana44's in my area that were taken out of Cherokee's and Comanche's. A Dana60 would be to far out of my budget.
If the MJ or XJ Dana44 is fitted with 4:56 gears, a locker, and pushing 36" tires... How well could I expect it to perform on and offroad?
Or, will I have the same problems, but not as often?
post #6 of 8 Old 01-24-2002, 08:43 PM
osburn
osburn's Avatar
Damn, I'd say you were gloating if I didn't know better! I didn't know about this limited slip electric locker. Seems like a waste to me. Oh well, gotta be different somehow I guess. I'd personally rather just run open and reduce the friction if it's a manual locker. I guess there will be a crowd that insists they need a limited slip and a locker. But that just doesn't sound realistic to me. Oh, and did you say it's still in development? Then I'm right, right? There ain't a limited slip locker...yet!
I'm pretty sure I read the Rubicon was going to have air lockers. Not ARBs. But some sort of low pressure actuation air lockers.
Depends on how hard you wheel. For 90 percent of the fellows out there, I'd say that would be damn near bulletproof. But, if you do a lot of hardcore wheeling, then you're right to assume you'll still have some carnage, just less often.
Matt Osburn
Score 1032
osburn is offline
post #7 of 8 Old 01-24-2002, 10:04 PM
RodeoRob
RodeoRob's Avatar
I believe Tractech unvieled a prototype at SEMA not too long ago. You can see mention of it on the official site, http://www.tractech.com/WhatsNew.htm
Yea, I thought the rubicon's lockers were air actuated ones built by Tochigi Fuji, not electric.
-Rob
Robert Gorrell
RodeoRob is offline
post #8 of 8 Old 01-25-2002, 09:37 AM
osburn
osburn's Avatar
Man! That sure is a lot of junk on the housing! I'm sure they could find a better location for some of that. I see no reason all that needs to be piled up on the axle housing.
Matt Osburn
Score 1032
osburn is offline
locker in the dana 30 ausra15 YJ Wrangler Technical Forum 9 11-01-2008 11:53 AM
dana 44 lsd locker ? 35boggers TJ Wrangler Technical Forum 8 07-24-2008 12:37 PM
Dana 44 & E-Z Locker? DaSham58 YJ Wrangler Technical Forum 1 02-08-2007 10:05 AM
Dana 35 and an ARB locker NvrStk TJ Wrangler Technical Forum 4 03-08-2004 01:03 PM
Dana 35C w/ a Locker ssg11bravo30 TJ Wrangler Technical Forum 12 11-08-2003 12:42 PM
