Better Heat in a YJ! - Page 11 - JeepForum.com
post #151 of 156 Old 01-01-2012, 10:13 PM
MDCustom
I might try making a set for myself using plastic plumbing pipe. I figure I will cut the pipe in quarters on my bandsaw. Then cut some pipe caps in quarters as well, and glue the pieces together. The only metal to fab up would be the brackets. Sounds simple enough... will let you know. I would like to come up with another mounting option as I don't like drilling holes into anything. If I don't like it, I would like to remove it without leaving a trace.
I might look into rare earth magnets....
MDCustom is offline
post #152 of 156 Old 11-12-2014, 11:15 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Bumping this awesome idea for the winter!
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #153 of 156 Old 11-14-2014, 10:03 AM
gtg413i
2003 WJ
I like it. You start selling these? The link didn't work for me. Need to install the better blower motor sitting on my porch first. I think somewhere someone made something to redirect the lower vents upwards also.
Brian's Black Betty Build:
gtg413i is offline
post #154 of 156 Old 11-15-2014, 06:08 AM
Mambo_Dave
Thanks for bumping this. What a great idea and thread.
Mambo_Dave is offline
post #155 of 156 Old 12-01-2014, 11:25 AM
mike134
I have a question,
My sister has a TJ and is always complaining about the heater. I don't have access to measure the dashboard on that vehicle. Would it be the same size as my YJ?
Also, is this useful on a TJ?
mike134 is offline
post #156 of 156 Old 09-07-2015, 08:56 PM
amp713
Have to get this done before it gets too cold!!
I like my YJ how I like my whiskey, on the rocks with just a touch of color!
amp713 is offline
No heat, then heat 2005X TJ Wrangler Technical Forum 6 10-17-2008 11:45 PM
Heat - no heat....... Heat - no heat Buford TJ Wrangler Technical Forum 3 10-13-2008 11:05 AM
No heat RacecaR YJ Wrangler Technical Forum 5 02-12-2006 10:43 AM
No Heat! youngjeeper11 YJ Wrangler Technical Forum 22 03-01-2005 03:32 PM
Very Little Heat 92wrangler YJ Wrangler Technical Forum 16 01-17-2005 01:50 PM
