Better articulation for YJ - JeepForum.com
post #1 of 20 Old 03-03-2013, 07:44 PM Thread Starter
BigWillyStyle
I hav a 91 YJ Wrangler. It has a 3.5 leafspring lift by Superlift. Its the way i bought it. Took it out for the first time to try it out and articulation is poor to say the least. I used to have a 89 cherokee, and aside from a 3 inch Rough country lift, it was completley stock, but went EVERYWHERE. A small incline with a small rut stopped my YJ so I cant even contiplait on taking it where my cherokee went. I have seen the suggestions on taking the rear track bar, and adding quick disconnects for the sway, what about removing the bump stops??? Any ideas on this or anything else that will help articulation. I wont do a spring over.
BigWillyStyle is offline
post #2 of 20 Old 03-03-2013, 07:50 PM
idskot
Rear track bar removal and quick disconnects / removal of the front sway has helped a lot of people have more articulation.
Removing the bump stops would only work if the axle hits the bump stop before the tire is close to the fender.
I could be wrong, but I believe the bump stop is to disallow the tire from hitting the fender / flare.
However, your Cherokee is going to have better articulation, as it has front springs vs front leafs. My only other suggestion might be the leafs themselves not being able to flex enough.
idskot is offline
post #3 of 20 Old 03-03-2013, 08:14 PM
cstone94
Check the shackle torque. Should be 45 ft/lbs
95' YJ - Warn Bumpers/Tire Carrier/Winch - 2.5L - 6" Skyjacker Suspension Lift - 4.10's - Locrite Locker - Dana 35/30 - 35" BFGoodrich KM2's
11' F250 - DD
1982 Toyota Pick-Up - Spray-On Yellow Rhino Lined - Chevrolet 305 H.O. - SM465 - NP208C - All-Pro Off Road 5" Springs - 35x15.50x15 Super Swampers
cstone94 is offline
post #4 of 20 Old 03-03-2013, 08:32 PM
GrouchyTim
Don't know why you would discount spring over right off the bat. Any spring under leafs are going to suck at flexing by the sheer nature of the beast. Going SOA with stock springs makes it a flex monster that can go pretty much anywhere.
Do the stuff mentioned above and that's really all you're going to get without getting softer springs.
'88 YJ with SOA and SYE and a bunch of custom crap from BWF in Chesapeake.
'97 XJ on 8" lift, double triangulated rear, long arm 3 link front, Eaton/60 with 5.14 gears.
GrouchyTim is offline
post #5 of 20 Old 03-03-2013, 08:33 PM
cstone94
It's also a $2500 job if done correctly.
11' F250 - DD
cstone94 is offline
post #6 of 20 Old 03-03-2013, 08:37 PM
zte87
GIVE IT THE ONION
zte87's Avatar
My 3.5 sua leafs flex fine in my eyes??
zte87 is offline
post #7 of 20 Old 03-03-2013, 08:48 PM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
A bit more info would definitely help. Have you put it on a ramp yet and maxed it out? Definitely best to identify what your constraints are before trying to game plan your next move.
How is your shock travel? What shackle setup are you running? How much bump stop?
Need parts? Need product advice? Contact Jason at
ArticRubi is offline
post #8 of 20 Old 03-03-2013, 08:49 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I don't think my spring under has a problem either
Luck Favours The Prepared
Anticanman is offline
post #9 of 20 Old 03-03-2013, 08:50 PM
OKwranglerYJ
3.5 lift flexes awesome.
OKwranglerYJ is offline
post #10 of 20 Old 03-03-2013, 08:55 PM
dillonjm
2013 WK
x3:
3.5" springs SUA don't have any issues. Disconnect your sway bars at a MINIMUM. They inhibit suspension movement by design for on road performance. Trackbars are the next thing to go. While your under there make sure you haven't overtorqued your shackles to something ridiculous.
Doe these and report back, your results are going to be drastically different.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #11 of 20 Old 03-03-2013, 09:34 PM Thread Starter
BigWillyStyle
Originally Posted by dillonjm View Post
x3:
Will do, as I said I am new to this front leaf suspension, and the lift came with the Jeep, where do I start in finding out what the shackles are torqued to, and where is the adjustment.
post #12 of 20 Old 03-03-2013, 10:11 PM
zte87
GIVE IT THE ONION
zte87's Avatar
Just back the shackles bolts back then torque them down to desired torque!
zte87 is offline
post #13 of 20 Old 03-03-2013, 10:23 PM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Have a read through the YJ FAQ under the stickies, there's a comprehensive list of torque specs for your rig as well as lots of other good info.
post #14 of 20 Old 03-03-2013, 10:33 PM
ashland82391
It's definitely not the leafs.
No tracks no sways with some stiff *** bastard packs.
ashland82391 is offline
post #15 of 20 Old 03-04-2013, 04:40 AM
prosneek
Take off the front and rear track bars if you havent already. They are not needed for a leaf spring vehicle. Also disconnect the front sway bar to get more flex. The new springs are just that, new and stiff. They are not as worn as the old ones and not as flexable.
Just rollin' down the road, smashing one import at a time.
prosneek is offline
