bestop supertop with soft doors question - JeepForum.com
post #1 of 7 Old 07-29-2002, 06:47 AM Thread Starter
battlestar
I've had my bestop supertop w/doors on for a week and had some questions for other people who also have it.
My soft doors do not seal at the top by the windshield. Is this normal? I get water leaking in.
Also, I don't really get how to fold it up. It doesn't seem like anything is holding it down. When I drove to work today it completely unfolded itself in the back of my jeep. I don't have a back seet to tuck it behind so it just blows all over the place.
OK, last question. The elastic strap that holds the bows down and tucks under the side rail, is there supposed to be one on both sides? I only have one on the drivers side.
My Ride: 1990 YJ, 4.2, 5 speed, msd ignition, TFI Cap, 4" skyjacker lift, 1/2" shackles, nutter bypass, bestop seats, herculined floor, Flowmaster, Oversized cat, Xterrains on Rock Crawlers
battlestar is offline
post #2 of 7 Old 07-29-2002, 07:48 AM
RCHavok797
RCHavok797's Avatar
Yes there should be one on both sides. The way I fold my top is by first flipping the side windows up on to the back portion of the top and then folding the front portion of the top over them. Alot of people take their side windows out but I have never had a problem with them creasing or getting in the way. It does help to have two people to do this but it isn't impossible to do it yourself, it can just be a pain in the a$$. Once that is done make sure the spreader bars are collapsed and then pop off the front peice attached to the windshield and slide the back bar forward while lowering the front peice you just removed from the windshield. If you have both straps you shouldn't have a problem with it unfolding. I do have a rear seat but I have driven with it forward before with nothing against the top and have not had a problem like you describe. I think your biggest problem is that you are missing the passenger side strap.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #3 of 7 Old 07-29-2002, 07:53 AM
RCHavok797
RCHavok797's Avatar
You also said that your soft doors don't seal right near the windshield, I think you are missing two pieces that attach on either side of the windshield and that are neccessary for the half doors. When I put my hard doors on with my hard top I have to remove these plastic peices.
post #4 of 7 Old 07-29-2002, 08:41 AM Thread Starter
battlestar
Thanks for the info. I'm going to get in touch with bestop. You were very helpful.
post #5 of 7 Old 07-29-2002, 08:49 AM
RCHavok797
RCHavok797's Avatar
Without those pieces I wouldn't be able to put my soft top up because that is how the front rails attach on my Jeep. How do you attach them on yours? Do you also have a set of full doors, that would explain why you don't have those pieces?
post #6 of 7 Old 07-29-2002, 08:50 AM
RCHavok797
RCHavok797's Avatar
Oh yeah, glad I could help.
post #7 of 7 Old 07-29-2002, 09:15 AM
johny1i
johny1i's Avatar
Regarding your door question, if you have the 2-piece doors, they may just need adjustment. There are three "poles" that slide into the bottom half of the doors. Two of the poles have 3/4" retainers with set screws on them that dictate how far the upper half slides into the lower half of the door. If you have a gap at the front edge of the upper half, either raise the retainer on the front end of the door so that the front half of the door sits lower (and thus more forward), or raise the rear. It takes a little playing around with it, but once you get those retainers where you need them, it's set for good.
Currently an '86 CJ-7 and a '77 CJ-7 Golden Eagle---#4 and 5 following a '01 Sahara, '90 Sahara, and '85 CJ-7....
johny1i is offline
New Bestop Supertop with half steel doors... yjrush YJ Wrangler Technical Forum 18 10-15-2007 05:52 PM
Bestop Supertop w/ 2 piece soft doors Old_man_emu TJ Wrangler Technical Forum 2 05-20-2006 07:09 AM
Bestop Supertop w/ 2 piece soft doors Old_man_emu TJ Wrangler Technical Forum 1 05-20-2006 03:18 AM
Factory soft top or Bestop Supertop, NSG370 question and a diff. CoriolisSTORM TJ Wrangler Technical Forum 20 04-21-2005 10:26 AM
Bestop Supertop with hard doors YJNotDone YJ Wrangler Technical Forum 6 04-26-2002 02:13 PM
