Bestop Sunrider. Yes or No? - JeepForum.com
post #1 of 9 Old 03-20-2010, 07:43 PM Thread Starter
manonthemoon
2010 JK Wrangler
Ok so im looking to buy a soft top for my 94 YJ and im almost set on the bestop sunrider but im not totally sure. Iv look on the some of the threads and didnt have much luck so i was just wondering if anyone has one and what they think of it, or if you think a different top is better?
Thanks
manonthemoon is offline
post #2 of 9 Old 03-20-2010, 07:56 PM
dodger889
They are a nice top. It's nice to be able to flip open the front open for a quick drive home from work. When you don't want to drop the whole top. Or when you are running down the open road and get off to cruise the back roads. The only weak point would be the back support bar and being able to keep the top tight.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #3 of 9 Old 03-20-2010, 10:45 PM
sjyj1989
I've got one and like it a lot. Very easy to open up and a nice option if I also know I'll have to button it back up quickly at home.
sjyj1989 is offline
post #4 of 9 Old 03-21-2010, 08:04 AM
youngYJ95
I love mine, the only thing I have had trouble with are the buttons on the windshield header breaking off and being attached to the top. Reordered and got a new one and no problems what so ever. Its great with full steel doors!
[Originally posted by rulppa: But no, there is no change is power.. and my arse-dyno is pretty accurate]
youngYJ95 is offline
post #5 of 9 Old 04-13-2010, 07:50 AM
83cjnut
1983 CJ7
I just wrote about my experience here:
http://www.jeepforum.com/forum/f9/an...l-like-335467/
1983 CJ-7, 4.2 258, MC 2100 1.08, TF999, D300, Team Rush'ed
83cjnut is offline
post #6 of 9 Old 04-13-2010, 08:06 AM
GreatWhiteMoth
I have had one for 12+ years. If some schmuck hadn't taken a razor to one of the rear windows it would still be pretty much perfect. I have used the sunroof option only a few times, but the main advantage in my mind is the quick release mounting method for the windshield. It's really easy to get the top back up and attached, and you spend a lot less time getting rained on than if you were using a windshield channel.
The main "down side" I can think of is that it doesn't use a windshield channel, so if you want to drop the top & run with a bikini, you will have to install a channel and remove it when you want the top back on.
That said, I stopped running with a bikini not long after I got this top, as it is good enough to just remove all the windows. Plenty of shade and all the breeze you can handle.
Another thing that can be a little tricky is when you drop the top, you have to be careful with the brackets that go around the doors, at least on the hard door version. I have forgotten a few times and ended up having to bend them back in to shape.
GreatWhiteMoth is offline
post #7 of 9 Old 04-13-2010, 09:01 AM
Wheelman286
Eh... Bestop makes good stuff which is why they have more or less monopolized the Jeep soft top market. But I think that fold back feature is just a point of failure myself. The more complicated something is the more likely the gremlins of decomposition will find a weak point in it.
The Bestop Halftop uses the same technology and I've heard stories of that front brace that keeps the top stretched failing in months. Bestop will replace it for free if it does break but I don't think it's worth the trouble.
You'll probably use it a few times and then just end up leaving it closed. That's how it would go for me I know that much and I also know this... if Bestop made a halftop that didn't have that fold-back feature... I'd buy one tomorrow.
92 Wrangler 4.0 5-speed -Canyon Blue Metallic/Black Interior '00 S2000 Silverstone Metallic/Red Interior '93 S-10 Blazer Tahoe LT Black/Grey Leather Interior
Wheelman286 is offline
post #8 of 9 Old 04-13-2010, 09:29 AM
evoGibson
i just un button my stock top and use the window straps for hte rear window to hold it back, kit works great.
1999 xj, bone stock-current
1998 xj, 2" on 33's-past
1994 yj on 31's-past
evoGibson is offline
post #9 of 9 Old 04-13-2010, 09:38 AM
matko25
its a yj just get a tarp and some bungy cords and keep in the back for when it rains
matko25 is offline
Bestop sunrider top cwbymt1973 YJ Wrangler Technical Forum 1 02-08-2010 04:37 PM
Bestop Sunrider blake2 YJ Wrangler Technical Forum 0 02-24-2008 07:13 PM
Bestop Sunrider mauleskyrocket TJ Wrangler Technical Forum 5 06-14-2006 10:04 PM
Bestop Sunrider. Tri_X_Troll TJ Wrangler Technical Forum 2 03-30-2004 11:05 AM
Bestop Sunrider Tiffy TJ Wrangler Technical Forum 3 08-05-2003 01:40 AM
