bestop soft doors - adjustment? - JeepForum.com
post #1 of 2 Old 04-27-2010, 09:23 PM Thread Starter
linusb
I need to lower my passenger side soft door so the clasp can better mate with the post. Do i need to take the skins off to make that adjustment? Any trick to it?
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #2 of 2 Old 04-27-2010, 09:39 PM
Burnerman
Burnerman's Avatar
If they're Superdoors there are nuts on the lower hinge. They're on the inside and you can get to them without removing the cloth. You can also bend them down slightly with you hands. I used my knee and hands to bend the metal frame to fit tight all around when closed.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
Bestop Soft doors and OEM half doors -compatability WillysEdition04 TJ Wrangler Technical Forum 6 11-25-2011 07:05 AM
Bestop makes 2 piece soft doors which match with Factory soft top? AROSETO TJ Wrangler Technical Forum 9 02-23-2010 12:41 PM
Factory half doors windows and bestop soft doors??? cpleasant TJ Wrangler Technical Forum 0 04-29-2008 11:40 PM
Newer TJ Half Steel Doors?....or Bestop 2 Piece Soft Doors sweetguardian00 TJ Wrangler Technical Forum 16 02-14-2008 08:21 PM
Bestop soft top soft doors question black05tj TJ Wrangler Technical Forum 1 03-02-2007 10:37 AM
