best Zero lift SOA springs - JeepForum.com
post #1 of 29 Old 11-06-2013, 08:21 AM Thread Starter
jamnjeep
Starting my SOA build for my YJ. Just picked up a Waggy 44 for the front and keeping the 8.8 in the rear.
Now I am trying to figure out the best choice for the springs, I really like the RE 1.5 SOA springs but do not want the extra lift. So it seems I have 3 choices:
1. Crown H/D 5 leaf pack springs = $440.00
2. Omix-Ada 6 leaf pack springs = $480.00
3. Alcan springs = $1,000.00
However I cannot afford/justify the cost of the Alcans. So that leaves the other two choices.
Is there other choices I am leaving out?
Will the Crown or Omix hold up to SOA application?
Any advise or fisrt hand experience would be great.
Thanks!
1994 YJ under construction....
jamnjeep is offline
post #2 of 29 Old 11-06-2013, 08:51 AM
jserna
1987 YJ Wrangler
I have no experience with either company's springs, however I have had experience with one more alternative for you. A friend of mine did a spring over on his 93 and what he did was take all of his stock spring packs to a spring shop here in town and had them add full military wraps and one extra spring to all of them. The spring rate was close to the heavy duty packs that were offered by Jeep. The jeep rides nice and flexes great. The added bonus was the spring wrap is almost all gone, he might in the future have a snail wrap added to the springs if he swaps in lower gears.
jserna is offline
post #3 of 29 Old 11-06-2013, 09:13 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Alcan hands down my buddy had been running them for 10 years soa and they have not lost any height at all. My alcans on my 95 were great SUA also.
Crown makes a good spring also. For my build I will be going with. Crown springs just cause I don't make the money I did in the past and my stock springs are trashed.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #4 of 29 Old 11-06-2013, 09:16 AM Thread Starter
jamnjeep
Thanks- good idea but I no longer have my stock springs, running 4" SUA now
jamnjeep is offline
post #5 of 29 Old 11-06-2013, 09:17 AM Thread Starter
jamnjeep
Also found these:
http://www.generalspringkc.com/product_p/97-567.htm
Never heard of general spring before but they have 4,5 and six leaf options...
jamnjeep is offline
post #6 of 29 Old 11-06-2013, 09:26 AM Thread Starter
jamnjeep
With the cost of highsteer, anti wrap bar, etc...not enough $$ to spend $1k on springs.
jamnjeep is offline
post #7 of 29 Old 11-06-2013, 09:27 AM
Tom95YJ
Tom95YJ's Avatar
Originally Posted by jamnjeep
Also found these: http://www.generalspringkc.com/product_p/97-567.htm Never heard of general spring before but they have 4,5 and six leaf options...
Nice find. 5 leafs would be about the stock rate. Those 4 leafs seem kinda soft I would worry about sag and axle wrap
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #8 of 29 Old 11-06-2013, 09:36 AM Thread Starter
jamnjeep
The 5 leafs are $120 while the 6 leafs are $80..weird.
Might as well get the Crowns for the same price, a lot more info out there on Crown than GeneralSpring. Mostly postive on theCrown springs.
jamnjeep is offline
post #9 of 29 Old 11-06-2013, 09:37 AM
survivor
Alcan
Thanks!
I have Alcan for sale! I just sold one set of Alcan for 700.00. I have one set left. Alcan springs will work great with 4.0 with front/rear bumpers such as tire swing up to 37s, winch , Lockers.
survivor is offline
post #10 of 29 Old 11-06-2013, 09:44 AM
Tom95YJ
Tom95YJ's Avatar
The 5 leafs are $120 while the 6 leafs are $80..weird. Might as well get the Crowns for the same price, a lot more info out there on Crown than GeneralSpring. Mostly postive on theCrown springs.
Simple solution remove a leaf from the 6 leaf pack.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #11 of 29 Old 11-06-2013, 09:45 AM Thread Starter
jamnjeep
Thanks, I saw your post on those in the for sale section. But I want stock height springs. Only going to run 36s and with the extra 2" jeeps no going in garage- can't have that..lol.
jamnjeep is offline
post #12 of 29 Old 11-06-2013, 09:49 AM
survivor
No problem. It has 6 leafs around the springs. You could take a leaf out of each of the spring?
survivor is offline
post #13 of 29 Old 11-06-2013, 09:55 AM
Norcal_chris
Norcal_chris's Avatar
I run 6 leaf pack up front. Its the main leaf and a second main cut down. Then the rest of the pack. The main and second cut main are clamped together. If you run a single main you will end up breaking leaves or bending them. I used two pairs of leaves to make my pack and just got them off craigslist for $70
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #14 of 29 Old 11-06-2013, 09:57 AM
Tom95YJ
Tom95YJ's Avatar
Good advise. Looks like I have more research to do. Thanks Chris
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #15 of 29 Old 11-06-2013, 10:21 AM Thread Starter
jamnjeep
x2.
jamnjeep is offline
