best way to soften up ride?? - JeepForum.com
post #1 of 16 Old 06-24-2006, 11:53 PM Thread Starter
bombadillo
I have a 93 yj 4.0 and it has a 3.5 inch superlift with the shocks included. I was looking for a way to soften up the ride. It is as stiff as riding on steel beams. I know the better lifts have better rides, but what are some ways other than loosening up bolts that I can soften up the ride some????
bombadillo is offline
post #2 of 16 Old 06-25-2006, 12:10 AM
bakwoodj2
Depending on how long the lift kit has been on, I would recommend taking it to a suspension specialty shop and having them re-arch the spring. I did that to my rear srings in my YJ and noticed a tremendous difference in the ride quality. My springs are the originals and I had one of my coworkers arch them up 2 inches and the added pep of the the re-arching worked wonders. Good luck.
2011 Natural Green Sport Unlimited
bakwoodj2 is offline
post #3 of 16 Old 06-25-2006, 07:35 AM
Neener Neener
Neener Neener's Avatar
I wouldn't recomment re-arching the springs just yet. Take off your track bars. Start with the rear and see how you like it. If you want it to soften up more, take off the front. Some people say the get more body roll/lean when they take off both, but most say it doesn't bother them enough to put it back on. Mine was a little stiff, so I removed the rear track bar. It made a world of difference. I didn't even bother removing the front. Let us know how it turns out!
There are no stupid questions, only stupid people.
Originally Posted by Al The Killer
My monkey likes your monkey
Originally Posted by Grape Ape
Just go get one and lick it when you get the urge.
Neener Neener is offline
post #4 of 16 Old 06-25-2006, 10:12 AM
GrimJeeper91
GrimJeeper91's Avatar
Losing the track and sway bars will only help. Also make sure the shackles are not torqued to 100 ft-lbs. I don't know about your shocks, but quality shocks can make a big difference as well. Greasables all around (shackles & maineyes) made a noticable difference when I installed them. Be glad you don't have Pro-Comp. I've had both Superlift and Pro-Comp and the SL was way softer.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #5 of 16 Old 06-25-2006, 07:37 PM
drexelsteve
you could pull the bottom leaf out of each pack, that'll soften it up a bit.
13 Rubi
drexelsteve is offline
post #6 of 16 Old 06-25-2006, 09:08 PM
jeeepguy
jeeepguy's Avatar
Switch to round springs.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #7 of 16 Old 06-25-2006, 10:22 PM
SeattleTJ
What is your tire pressure? I aired mine to 25lbs from 35 and loosened the shackle bolts and replaced the nuts with nylocks so they don't rattle off. World of difference.
1999 TJ, 4.0, AX15 5-Speed, NP231, Dana 30 open 3.73, Dana 35 Detroit Locker 3.73, Rough Country 2.5" suspension lift, 1.25" body lift, 2.2 shocks/stabilizer, JKS Discos, 33 x 12.50 Mickey Thompson MTZ tires on 15 x 8.5 MT Classics
SeattleTJ is offline
post #8 of 16 Old 06-26-2006, 02:08 AM
claybob
claybob's Avatar
I don't know how old your springs are, but if you just put them on then they will probably soften up a little as you break them in. Tire pressure does wonders also. You can remove the bottom spring and it will be a world of difference. My brother did that on his CJ 5 with a Pro Comp lift and it improved it alot but his springs started sagging really early in the game too so I would try everything else before I did that.
04 LJ, 4" RC Susp Lift, 35x12.50 Mickey Thompson Baja Claws
claybob is offline
post #9 of 16 Old 06-26-2006, 04:12 AM
yellow2kgt
If you don't already have them.. Get some greasable shackles and torque the bolts to 40 ft/lbs. Doing that made a huge difference in my ride quality.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #10 of 16 Old 06-28-2006, 09:30 AM Thread Starter
bombadillo
Well, the springs are still relatively new, so they are still stiff, but the PO had them all put on. I have loosened the shackles slightly and used a little lithium grease not that it did anything, I have my tires set to around 28 lbs of pressure, and its a superlift 3.5 lift. The rear sway bar was gone when I got it, and the track bar is too. I'm probably going to take the front sway bar off just to see how it drives, and then if its undrivable, throw on quick disconnects or make my own.
post #11 of 16 Old 06-28-2006, 09:34 AM
paultyler
Uncle Paul has spoken...
paultyler's Avatar
In this order:
1. Air down to 25, or even 20.
2. Make sure the shackles are not on too tight. If they are your ride will be very harsh.
3. Try different shocks.
After those three things are done, the only thing left would be to replace the springs with something less stiff.
I do not believe the track bar or sway bar are going to make your ride stiff. They simply control stability, so save your time working on disconnects.
I had pro comp for a while. They sucked. Ultimately I had to buy new springs to fix my ride.
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers,
, custom cv driveshafts,
, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s,
, Teraflex Bellyup,
, rock lights, RE hand throttle, M.O.R.E. roll cage,
, 9000lb winch with synthetic cable
(12voltguy.com), Dual Blue Top Optimas with
dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline
post #12 of 16 Old 06-29-2006, 10:13 AM Thread Starter
bombadillo
yeah, the shocks that are on it are no name and I would definitely say that they came with the kit or the po before me scrimped pennies and just put cheap shocks after he bought the kit. I would really like to change out to a good shock, but what would you guys recommend for a 3.5" superlift riding with bfg mt 32x11.50 tires?? I have looked at the 5150 more because I liked the looks, but hows performance on those things? I used to be a rancho fan, but they ride like a rock as well. What would be the softest riding usable shock out there for a reasonable price?
post #13 of 16 Old 06-29-2006, 10:18 AM
atomicmoose
Just call me Moose
atomicmoose's Avatar
Trac bars link your axle to the frame....you better believe that they will stiffen the ride. Bumps are more harsh as well.
I removed my rear trac bar and my sway bar....world of difference...front trac bar will be next.
atomicmoose is offline
post #14 of 16 Old 06-29-2006, 10:44 AM
letsroll
A track bar will only stiffen the ride if they are at a large angle. When at such angle the rise and fall will cause a push to the frame, but usually will result in a twitch also (like a slight side to side bump) whereas the push is not directly up and down. It is kind of the same effect on ride as bump steer is to steering. If the track bars are on anything near a parrallel plane (ideal set up) then there will be very little if any effect on ride stiffness.
03 Renegade DD
99 Sahara DD
letsroll is offline
post #15 of 16 Old 06-29-2006, 10:58 AM
atomicmoose
Just call me Moose
While this is technically true, my ride softened a lot after the rear trac bar was removed.
any way to soften up throttle? KI4KWF TJ Wrangler Technical Forum 12 07-29-2007 09:49 PM
Will new front control arms soften my ride? Roothog TJ Wrangler Technical Forum 13 04-21-2006 09:51 AM
How to soften ride?? itsajeepthing17 YJ Wrangler Technical Forum 1 12-17-2005 12:44 AM
How to soften ride?? itsajeepthing17 YJ Wrangler Technical Forum 20 12-15-2005 12:09 PM
Soften up the ride a bit? nosajmc YJ Wrangler Technical Forum 11 09-15-2003 01:39 PM
