Best way to get Water out of gas tank?? - JeepForum.com
post #1 of 141 Old 03-19-2012, 12:33 PM Thread Starter
janders82
2010 JK Wrangler
I'm looking for options to get water out of the gas tank & fuel lines WITHOUT dropping the gas tank. I live in an apartment complex and don't have the means or space to drop the tank.
I've heard a few people mention Sea Foam or Denaturalized Alcohol...anyone have any luck with either of these??
I was thinking about emptying the tank and using some sort of additive.
Thoughts/Opinions are greatly appreciated!
janders82 is offline
post #2 of 141 Old 03-19-2012, 12:36 PM
Louie4
Have you tried a bottle of Heet? It absorbs the water and acts a gasoline anti-freeze. Worth a shot at least. You can get it at any local auto parts store.You could also pull the fuel filter loose and let the gas pump out into a bucket...away from heat or sparks.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 141 Old 03-19-2012, 12:39 PM
CrawlingForward
I guess the main question is how much water?
Just a little, heat or seafoam should do.
A lot, you may need to drain it at the fuel filter (if it's enough that the fuel is no longer usable at all).
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #4 of 141 Old 03-19-2012, 12:40 PM
tyler1234567
Put a double dose off heet and burn off that tank
tyler1234567 is offline
post #5 of 141 Old 03-19-2012, 12:43 PM Thread Starter
janders82
2010 JK Wrangler
Haven't tried HEET. Haven't tried anything for that matter, yet. I did just pick up a bottle of Sea Foam though. Hopefully this works. I ended up with some water somewhere while I was wheeling over the weekend. I'm thinkinking there is definitely water in the fuel...
post #6 of 141 Old 03-19-2012, 12:45 PM Thread Starter
janders82
2010 JK Wrangler
I'm really not sure how much water. Enough to make my Jeep sputter when giving it more than half throttle while in gear...
I got in a sticky situation for less than a minute. Can't imagine too much water could have got in anywhere??
post #7 of 141 Old 03-19-2012, 12:55 PM
CrawlingForward
Have you considered other causes? Moisture in tue distributor cap, etc?
post #8 of 141 Old 03-19-2012, 12:59 PM
Louie4
What exactly did you get into? Did your jeep start sputtering after that incident?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #9 of 141 Old 03-19-2012, 01:00 PM
pete1991YJ
Denatured alcohol or HEET is what we use up north here... the water in the gas happens every year usually un the fall up here. I had the same prob last year till I dumped the old gas, dried out the tank, and ran a few cans of HEET thru it. You might wanna try about 3 cans first, its only about $2 each can. That way if it works, you don't have to drop the tank.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #10 of 141 Old 03-19-2012, 01:06 PM
Que89YJ
If you are looking to get rid of the gas you can pull the hose at the fuel rail and jumper the fuel pump relay. I don't know how much gas you have in it but the fuel pump will empty a full tank in under 10 minutes.
Que89YJ is online now
post #11 of 141 Old 03-19-2012, 01:21 PM Thread Starter
janders82
2010 JK Wrangler
sure did. I replaced the dist cap since i had a new one laying around. No water in the airbox. Installed new fuel filter...and now i'm on to water in the fuel...
post #12 of 141 Old 03-19-2012, 01:24 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
stab the bottom with a screwdriver, i would imagine that would drain it pretty good.
just kidding, lots of good suggestions posted already
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #13 of 141 Old 03-19-2012, 01:25 PM Thread Starter
janders82
2010 JK Wrangler
I was up here in Alpharetta doing some light wheeling. Found some failry cool trails -- ran across a mud puddle that happened to be much deeper than expected. Muddy water up to my floorboards!!!
everything seemed fine until I got off the trail and back on the road. It was sputtering BAD. put some gas and fuel system cleaner in the tank, and it drove fine for about 5+ miles before the sputtering came back.
post #14 of 141 Old 03-19-2012, 01:32 PM Thread Starter
janders82
2010 JK Wrangler
LOL - i actually read a post on aother forum where a mechanic suggested that to someone! NO WAY!!!
post #15 of 141 Old 03-19-2012, 03:00 PM
lwow
Maybe the cps is crudded up? How empty was the tank & did you fill it? If that is the breach you need to fix the leak too if its not the cap.
95 YJ 4.0 5spd
98 Ram 2500 4x 24v CTD
78 Scout II SD33T
70 Scout 800 SR2 sv304
lwow is offline
water in gas tank jgresham75 YJ Wrangler Technical Forum 4 05-15-2011 10:09 PM
Water Tank idea. Vertisce JK Wrangler Technical Forum 40 08-25-2009 12:09 PM
Water in your gas tank - Does it work? Urb4nTr0ll YJ Wrangler Technical Forum 46 03-12-2009 10:31 PM
Why does water boil in my overflow tank Fargo TJ Wrangler Technical Forum 23 07-21-2006 12:00 AM
Water in Fuel Tank... Duh-oh! Goyo TJ Wrangler Technical Forum 3 10-24-2004 04:17 PM
