best way to find out what size lift? - JeepForum.com
post #1 of 4 Old 07-30-2003, 02:18 PM Thread Starter
AK1904
whats the best way to find out how many inches of lift i have...i have a pro comp suspension and am running 33x12.50s but cant tell how much lift i have
AK1904 is offline
post #2 of 4 Old 07-30-2003, 02:37 PM
UPnOVER
UPnOVER's Avatar
If there is a lot of room and you never rub then it's the 4" but if you rub the tires a lot then the 2 1/2" would be it.
I get older and they stay the same age.
RED JEEP #6
91' YJ, D30 EZ, F8.8 locked & 410's, BDS4+" lift, 35" BFG's on 15x8 RC, 8,000lb Ramsey, etc.
rock-nutz.com
UPnOVER is offline
post #3 of 4 Old 07-30-2003, 09:44 PM
Moxley
Moxley's Avatar
2017 JK Wrangler
Measure from the bottom of your rocker panels. Stock panels are 18" off the ground with the stock 27" tires.
Example: If your Jeep measures 24" at the rocker panels and you are running 31" tires, than your lift is 4".
(6" higher than stock measurement at panels, minus 2" from total for the increased tire height)
Doug
Moxley is offline
post #4 of 4 Old 07-31-2003, 12:10 AM
87yjNY
Moxley
Hi there Moxley,
I checked out yer jeep pic in your signature- very nice jeep there.
What kind of lift do you have? Which company? Do you recommend it for on-road use...maybe 2% ill be using it offroad...did you buy online? website?
Did you need any mods with the 3" suspension? pitman drop or SYE? or was it pretty straight forward...tell you the truth, yours is the first jeep with lift that I wish mine looked like...I love the lift.
Also, did you buy new or longer shackles? or are they the stock shackles? Please advise what you think. Thanx. Post here and /or email me info/pics at Vista50@aol.com
Elliot
87yjNY is offline
A used lift? How would you find it? ocTJ TJ Wrangler Technical Forum 6 12-22-2009 08:23 PM
cant find tire size online anymore CreepyCrawler95 YJ Wrangler Technical Forum 12 04-26-2009 08:32 PM
Opinion about tire size vs. Lift kit size awol09 TJ Wrangler Technical Forum 25 09-29-2008 06:17 PM
TPS or something else, help me find the right size radiator bolt veritas4156 YJ Wrangler Technical Forum 8 01-24-2008 07:29 PM
Can't find my rim size... RobC TJ Wrangler Technical Forum 4 07-14-2002 01:21 PM
