The best U Joints for the Dana 30 axle - JeepForum.com
post #1 of 26 Old 11-16-2012, 10:37 AM Thread Starter
Dake
Dake's Avatar
I want replace my factory U joint. What is the best brand to use? Greaseable or sealed?
Dake is offline
post #2 of 26 Old 11-16-2012, 10:38 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
If you're looking at the best, check out CTM.
Luck Favours The Prepared
Anticanman is offline
post #3 of 26 Old 11-16-2012, 10:51 AM
jbolty
jbolty's Avatar
I have tried them all and the best, aside from CTM, is spicer. Also, I have better luck with the non greaseable; guessing the lack of a drilled hole means more metal.
jbolty is offline
post #4 of 26 Old 11-16-2012, 10:55 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
I have never experienced the benefits of greasable. Sometimes I use them, some times I don't. I have seen them all break.
Poke is offline
post #5 of 26 Old 11-16-2012, 11:05 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Does anyone think that the greasable function will displace water (assuming the axle is submerged) and prolong the life of the joints?
post #6 of 26 Old 11-16-2012, 11:09 AM
jbolty
jbolty's Avatar
I'm sure that's true but mine have always broken long before wearing out.
On the other hand, the spare shafts I carry are the originals from 1990 and pretty sure they have the original joints. But, my pile was never offroad until I got it.
jbolty is offline
post #7 of 26 Old 11-16-2012, 11:15 AM Thread Starter
Dake
Dake's Avatar
Thats what I was thinking. The CTM's are a little or a lot higher than I was looking to spend. Over 200 a side
Dake is offline
post #8 of 26 Old 11-16-2012, 12:46 PM
SunDevilJeeper
Does CTM even make u joints for the D30? All I see on their website are D60 and D44 u joints.
1991 YJ: Daily Driver
1992 YJ: Pile of crap sitting in the garage.
SunDevilJeeper is offline
post #9 of 26 Old 11-16-2012, 12:47 PM
BlueRubiconrich
get a good dana spicer non greasable U joint
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #10 of 26 Old 11-16-2012, 12:51 PM
CJ51973
CJ51973's Avatar
I always ran greasable in my CJ. I always gave them a pump after they were submerged. The Spicers didn't seems to push much of anything out but it did on the cheaper ones. I have been running the sealed one that were in my YJ for 3 years now and they are stil fine. How's that for an answer. Vague. I should be in politics = ). The only joint I ever busted was a greasable through the cap type spicer on a Dana 44.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #11 of 26 Old 11-16-2012, 01:02 PM
evan1395
+1 on this. When it comes to OEM Jeep Parts, you cannot go wrong with Spicer Products. If you're gonna do one side you might as well do the other. I'd reccomend sealed units. Unless you do alot of dry sandy/dirt type driving that really sucks the grease out of the U-Joints, in which a Zirk fitting is a must. I'd go with (2) Spicer 5-760X's
evan1395 is offline
post #12 of 26 Old 11-16-2012, 01:12 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
There are several ujoints that will fit different shafts for the Dana 30 axle.
post #13 of 26 Old 11-16-2012, 01:43 PM
PeteYJTJ
I'll add here that I paint an "X" on the ujoint caps and axle ears. That way you can see if a ujoint cap spins in the axle. If it does, that means the joint should get replaced.
I've seen somewhere a joint where all 4 caps have zerk fittings in them. This allows the joint to be greasable, but without the thru-holes in the joint body. I thought that was cool, but now don't remember where I saw it, though I haven't really looked much. I run non-greaseables now.
Good luck
Pete
88YJ:SOA/locked/35s/Superwinch=Wheeling Jeep.
04WJ:4.0/3"+10mm/Superwinch=DD & Expedition Jeep.
PeteYJTJ is offline
post #14 of 26 Old 11-16-2012, 01:54 PM Thread Starter
Dake
Dake's Avatar
Anyone run the Moog joints? I can get them today. They have greaseable and sealed.
Dake is offline
post #15 of 26 Old 11-16-2012, 07:29 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Deals are out there.
I got 2 CTM's for $75. I will admit, it does help to be good friends with the guy who engineered them.
The D44 CTM's are of the 760 flavor, so if you have the smaller Spicer 260 series axle shafts (like those that the OP has) with the smaller ear holes, the CTM's won't work (unless you machined them to accept the larger ujoint caps - but its not a good idea to install CTM's in a non-chromo type shaft. CTM's are happy with a Superior or Warn shaft).
Problem is - the OP can not run that series of ujoints because his year YJ can not fit them unless he has the ears machined.
CTM's have a needle grease fitting in the top of each cap.
I ran CTM's for several years when I had a D30 up front.
CTM's have no needle bearings - which allows for the ujoint cross section ends to be larger - plus the 300M material is far superior to the "standard" material.
The caps are sleeved with bronze, and rebuild-able, plus a lifetime warranty.
260 series (not a Spicer) on the far left, Spicer 760 middle, CTM right.
Caps for each. Notice how whimpy the 260 series needle bearings are.
These are my old Warn shafts with CTM's installed.
Joe Dillard is offline
