best shackles for a comfortable ride - JeepForum.com
post #1 of 11 Old 10-08-2013, 10:27 AM Thread Starter
Xzero117
I'm about to pull the trigger on a 2.5 OME lift, my jeep already has a prothane body lift
the last piece of the puzzle would be a set of shackles to complete the suspension
I'll also be replacing swaybar links, the tierods, all the bushings
this jeep will be on the road 80% of the time, this is mostly my roadtrip vehicle/ blizzard mobile
Xzero117 is offline
post #2 of 11 Old 10-08-2013, 10:29 AM
superj
i have boomerang shackles on mine and am in the process of installing an ome 2.5
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 11 Old 10-08-2013, 10:35 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
Some nice boomerang shackles with greasable bushings would do the trick. You can get them from several manufacturers. Here is where I got mine since they are semi-local to me http://www.mountainoffroad.com/_e/de...les_Plates.htm
You can also PM this guy to keep it in the JF family. He is probably cheaper too http://jeepspace.jeepforum.com/BESRK
Randonexplosion is offline
post #4 of 11 Old 10-08-2013, 03:08 PM
Sparrows
x2 on the BESRK shackles.
They are WAAAAAy cheaper than the MORE shackles. You do have to paint them and source your own hardware though. I spent about $6.00 on bolts and sleeves when I bought his shackles, so no biggie.
His shipping was fast and the product was nice and beefy. Can't go wrong with them.
Cheers
June '13 YJOTM
Sparrows is offline
post #5 of 11 Old 10-08-2013, 03:29 PM
rogerv
X3 on the BESRK products, I have them on all 4 corners. Great customer service and product.
If it's not broke- modify it, so it won't break
rogerv is offline
post #6 of 11 Old 10-08-2013, 03:56 PM
coolin4u
Same here
coolin4u is offline
post #7 of 11 Old 10-08-2013, 04:26 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
X4 on Eddies stuff he made the front bumper on my 95. It was great. Planning on getting some of his booms for the smurf
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #8 of 11 Old 10-08-2013, 07:04 PM
timatoe
timatoe's Avatar
I have booms on mine too, but the shackle themselves aren't going to make a whole lot of difference. What will make a difference is how tight you make them, they certainly do not need to be tightened down to 60 ft. lbs.
timatoe is offline
post #9 of 11 Old 10-08-2013, 09:58 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
This is important
The red is the inner steel bushing and is paramount for proper shackle dynamic.
Luck Favours The Prepared
Anticanman is offline
post #10 of 11 Old 10-08-2013, 10:53 PM
imstillatwork
This is all that matters for shackle 'comfort'. Anything else is for another reason (booms for inversion etc, greaseable is a maintenance issue, not a performance one, lift is variable depending on needs.)
This is important
imstillatwork is offline
post #11 of 11 Old 10-09-2013, 12:31 AM
fratis
fratis's Avatar
If they are designed proper you can make them as tight as you want and still move freely.
-insert meaningless out-of-place political diatribe-
fratis is offline
