Best replacement axles? - JeepForum.com
post #1 of 8 Old 10-17-2001, 10:26 PM Thread Starter
yjjeepin
I need to know some good axles to put in that are easy to put in and not too expensive, and where can i find these axles,on what kind of truck, the axles are going to be on a soa lifted jeep
yjjeepin is offline
post #2 of 8 Old 10-18-2001, 06:42 AM
RodeoRob
RodeoRob's Avatar
For the rear, i bet many would agree the Ford 8.8 is a great swap. They're found on 96+ Explorers. 31 spline, 5 on 4.5", width is about the same, disc brakes, monster tubes... in most cases you could be able to find one for around $400-500, maybe cheaper if you look.
For the front, you might consider staying with your D30. I believe if you have a 95 or newer, you get the D30 with the 297x ujoints. These are the same ujoints on a D44 and this is usually the first point of failure.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 8 Old 10-19-2001, 10:33 PM
bighair
hey, normally, if you cahnge the rear, wouldn't you also change the fromt if you had the ca$$?? and would it be possible to swap the front of the ford as well??
Thanks
Reg
Team Mod Squad
We are here to help YOU!
bighair is offline
post #4 of 8 Old 10-20-2001, 12:37 AM
Nightclaw
The only mandated change to the front that could be dictated by a rear axle swap is gear ratios. For example, I'm having a Dana 60 installed next Thursday, but the only change to the front end is that I'm having 4.56:1 gears installed in an otherwise stock Dana 30. Reason being is that my rig has 3.07 gears right now, but 3.07's don't exist for a D60 (not that I'd want 'em if they did... ). Hence, I am forced to regear the front axle to accommodate the rear.
The Dana 30 reverse-cut model that's standard on YJ's is a fairly decent axle from what I've seen, and '95 and later (I believe) use the same steering U-joints as it's big brother Dana 44. Get rid of the hokey vacuum disconnect, and the D30 is quite a rugged little axle for it's size. Cheers!
Nightclaw is offline
post #5 of 8 Old 10-20-2001, 09:57 AM
bob91yj
The Ford 8.8" axle seems to be popular, but not the best option. It still has C-clips, which means you still have to carry spare axle shafts. I'll probably go the D44/D60 route whaen I upgrade. I was pretty much set on the D44, but Nightclaws research has me leaning toward the D60 now. It seems there's only a couple hundred dollars difference between the two, at least at MIT.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
post #6 of 8 Old 03-05-2002, 08:29 PM
BzJeep
BzJeep's Avatar
I am maybe getting a 93 YJ 6cyl and I want 35" BFG MT's and I was wondering what I need to do underneath the Jeep. (gears, drivetrain, axles)
Thanks
2008 Metropolitan Gray Mazda3S Sport
2001 Steel Blue Grand Limited *SOLD*
1993 Forest Green Wrangler *SOLD*
Green Jeep Club Member #16
BzJeep is offline
post #7 of 8 Old 03-05-2002, 10:46 PM
kidwired
kidwired's Avatar
Thanks
Reg
No and yes
94 yj SOA +3.5", 35" swampers.
kidwired is offline
post #8 of 8 Old 03-06-2002, 09:06 AM
Keith Strong
1978-9 Ford F250 D60's front and rear.
Which lever do I pull?
Keith Strong is offline
Dodge axles VS Ford Axles???? Allen52105 YJ Wrangler Technical Forum 7 08-07-2009 01:23 PM
Superior axles vs. Alloy axles BusyDoinNothing TJ Wrangler Technical Forum 21 06-30-2007 12:40 AM
replacement axles shafts rubi03 TJ Wrangler Technical Forum 16 06-29-2006 06:17 PM
Best vehicles for replacement axles Down&Dirty TJ Wrangler Technical Forum 1 07-11-2004 10:51 AM
For Sale: Replacement Axles for D30 jbhawk YJ Wrangler Technical Forum 2 04-16-2002 07:36 AM
