Best (reasonable) junkyard swaybar for YJ - JeepForum.com
post #1 of 16 Old 03-13-2013, 06:30 AM Thread Starter
soonermatt
(Search isn't finding any answers so I think I'm asking something which isn't asked often.)
Long story short, I've gone SOA which has lowered my rig and given me much better flex up front.
After 6 years without, I need a sway bar again. My old sway bar is at the bottom of some scrap pile at a dealership.
Does anyone have any recommendations for the best sway bar to pull from Pull-a-Part? We don't have any Wranglers in our pull-a-part but we have many XJs and WJs.
PS: I know about the electric disconnect sway bar off the new jeeps for $1700. I've *heard* about using a Chevy torsion bar as a sway bar similar to a Currie Anti-rock bar. I couldn't find supporting information. Thank you.
soonermatt is offline
post #2 of 16 Old 03-13-2013, 09:44 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Just put an ad in the classifieds section for one.
Luck Favours The Prepared
Anticanman is offline
post #3 of 16 Old 03-13-2013, 09:49 AM
Chrisnvegas
Chrisnvegas's Avatar
If you know anyone who is traveling to Vegas, trucker or otherwise, you can have mine. Because it's a desert Jeep, it's still factory painted black. All the rubber is still in good shape. I even saved the factory hardware.
It's free but how can I get it to you?
"Auto racing began 5 minutes after the second car was built."
Henry Ford
Chrisnvegas is offline
post #4 of 16 Old 03-13-2013, 10:16 AM Thread Starter
soonermatt
Thanks guys. I put an ad in a local jeep club and a couple guys answered.
I'm still curious about what I'd heard using a Chevy truck torsion bar to make your own Currie anti-rock sway bar. I can't find any info on that one.
post #5 of 16 Old 03-13-2013, 12:37 PM
Awesome
I for one would love to know how you went SOA and lowered your ride by doing it.
100 Characters is not enough to have an interesting/relevant signature.
Awesome is offline
post #6 of 16 Old 03-13-2013, 12:42 PM
SeanB95YJ
it's that new suspension system that's all the rage... Springs On Asphalt
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #7 of 16 Old 03-13-2013, 12:47 PM
Awesome
Oh yeah, I heard about that. I hear the sparks make great underbody lighting! Especially after the ATF coming out of your slip yolk ignites!
Awesome is offline
post #8 of 16 Old 03-13-2013, 07:58 PM Thread Starter
soonermatt
Sure! I had ghetto 4" lift springs and 1" boom shackles. I switched over to bastard pack Isuzu Rodeo / Cherokee springs, restoring to factory shackles and moving the hangers forward.
It's really a great suspension. While I'm at it I want to tighten it up in turns.
Stretch + LCOG is the way to go.
post #9 of 16 Old 03-13-2013, 09:21 PM
Awesome
Maybe it's just me, but I think stretching is stupid. The reason we don't drive trucks instead of Jeeps is because we WANT the short wheelbase with the high ground clearance. Lengthening your wheelbase = lower ground clearance.
I can see why some people do the stretch, but really, just going with big tires will give you the same effect, and keep your ground clearance.
Awesome is offline
post #10 of 16 Old 03-13-2013, 09:44 PM
USMCBuckWild
I have a complete sway bar setup with brand new links for the front of a YJ. Its extended sway bar links, not sure how long from stock they are
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #11 of 16 Old 03-14-2013, 07:36 AM Thread Starter
soonermatt
In reality, we all build the jeeps the way we want them. You have your 31" tires and Dana 35 axle...that's your choice.
I'm trying to do a little different. I've ran your setup in the past, I'm trying something different now. If you want a shorter wheel base vehicle that's your choice. You can even shorten yours if you like.
I think there is probably an evolution of a jeeper and there is a chance you might make it this far some time. Later on, you might get the desire to run 35s and 37s, you might experience a roll over or two, you might start doing some hard trails where a 4" lift isn't feasible. You might not.
We all build our rigs the way WE want and I'm not about to tell anybody how to build their own rig.
Back on topic -- it doesn't sound like anybody has any advice on the best junkyard sway bar for our rigs.
post #12 of 16 Old 03-14-2013, 08:03 AM
skyj
Simply because when you lift a Jeep and put bigger tires on it you loose the original HEIGHT-to-LENGTH ratio that made it so capable from the factory. This ratio is further exaggerated when we add bigger tires and lower gears which create's more torque resulting in a very unstable feeling on and off-road!
The magic number seems to be around 100" for most people it works well in most situations. I am stretched 4", two in front and two in rear. I had many factors in wanting to stretch it. for instance in the front of YJ's if you go up to a 35" tire the first time you flex it out an turn the wheel you are into the back of the fender plus I think there is too much that sticks out in front of a YJ, the closer to the front of the jeep the tire is the better your approach angle and vise versa with the rear. In the rear the longer the driveshaft the better the angle you have. The bigger the tire you go on a stock YJ wheelbase the more unstable you will feel climbing hills and what not. I like my 4" stretch with 35's it feels verly stable climbing.
On topic I've heard Toyota torsion bars work good as sway bars. All in all without a lot of trial and error it might be best to go with a stock sway bar, if it will still fit with your stretch.
build thread:
skyj is offline
post #13 of 16 Old 03-14-2013, 08:25 AM Thread Starter
soonermatt
Bam!
This is exactly what I am looking for. I don't want a "status quo" sway bar if possible. I'd like to get a little creative. I might start looking around at this.
Now I need to learn about torsion bars...
post #14 of 16 Old 03-14-2013, 04:11 PM
Awesome
Yeah, I get that. I eventually want 35s. Some people have the money to build their Jeeps, some people have to wait for years and leave it the way they bought it. I was actually going to swap out the D35 not too long ago, but the 10-bolt I was going to swap in wouldn't have made enough of a difference to make it worth the work.
Okay thank you. That explains the issue much better. I have driven a stock-length TJ on 35" tires, now I know why it felt so odd.
As far as torsion bars go, seems like you should be able to mount it across the front end, with bars coming off at the ends pointing rear. Then you could use the regular sway-bar disconnects to attach those bars to the axle. I would think any torsion bar would work for this kind of setup, but it's the same as using a regular sway bar. How exactly are you wanting it mounted?
Awesome is offline
post #15 of 16 Old 03-14-2013, 04:38 PM
skyj
If I understand what sooner is wanting correctly is he wants something similar to an anti-rock sway bar, but without the price tag. It may take a bit of RI to make work. with a torsion bar mounted through the front tube crossmember with some bushings. you would have to build some kind of arm with splines in it to attach to the axle.
Here is a link to a Pirate thread on themhttp://www.pirate4x4.com/forum/gener...d-swaybar.html
build thread:
skyj is offline
junkyard , swaybar , YJ
