so here is my dilemma i want to eventually end up on 33's and am looking at replacing my springs at this time. i am torn between ome 2.5, bds 3.5, or the zone 3.5 i heard they are bds under different name? told i will need to do a body lift if i go with the ome. what to do? anyone running any of these set-ups? what are thoughts? the bds and ome are pretty close in price. thanks
I have 4 inches of lift, and at full flex my tires just rub the factory fender flairs. Also with that much lift you will either need to do a T-case drop or more preferably a SYE and new drive shaft.
2.5" springs, half inch lift shackles, 1"body lift and 33's, 1 inch motor mount lift and no vibes. Then every jeep is different. If you got money to spend I'd do 3.5 or 4 inch lift and sye and drive shaft
Pictured: OME springs, 5/8 shackles, 1" body lift, TJ flares on 33s. There is enough room but after a while the tires started pushing up the front fenders so a year or so after this I did a high line with tube fenders on 35s.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
