Best oil pan gasket for the 2.5? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Best oil pan gasket for the 2.5?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAwesome savings at openboxoffroad.comNitro Gear Packages Now Available at Rockridge 4wd
Unread 01-19-2015, 06:00 PM   #1
bobs409
1987 YJ Wrangler
I'm just full of questions today.
I see there is a rubber 1 piece oil pan gasket available or a 4 piece set that uses cork side gaskets.
What's the better one to go with?
Also want to sneak in one more question. Is there a seal or gasket at the distributor? I see oil leaking there. ??
Thanks,
Bob
bobs409 is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 06:36 PM   #2
Luuca
TYPICAL /F12 HOOLIGAN
Luuca's Avatar
I dont see a Felpro kit that is one-piece for an 87 2.5L available. On our 91 2,5l we used a 4-piece rubber set, and I also used a thin coat of Black RTV so around the lip of the pan to help seal it. If you use the Cork/Rubber kit, make sure you get the Felpro 4-piece set that includes the lower edge seal for the timing cahin cover. A little RTV couldn't hurt either.
Yes there is a circular paper seal that sits between the distributor stem seat and the block. If you are leaking, get a new one Felpro Gasket
91 YJ "Alice" 2.5L, AX5, 2.5" OME 36Rs, 1" Shackles, 32" Yoko ATs, 4.10 D30/35 Busted Knuckles
05 LJ Rubicon "Ghost" 4.5" RE, 1.25" BL, 33" Atturo MT, 4.10 D44 F/R Locked
/f12 MOAB 2015
Luuca is offline   Reply With Quote Quick reply to this message
Unread 01-20-2015, 02:53 AM   #3
1Coyote
Junior Member
1Coyote's Avatar
Best advice on a pan gasket is to make sure the bolt holes are flat,no dimples, clean all surfaces of any old material, use a thin coat of rtv as previously suggested and do not over tighten the bolts. Too often people over tighten the bolts which deforms the pan. It may seal well at the time but the next time it's changed those bolt holes will seal tighter than the rest of the gasket and could result in a leak. If you find any bad spots, place the lip of the pan on a 1x6 board and gently hammer the hole flat.
Flat mating surfaces is the key to any good seal.
1Coyote is offline   Reply With Quote Quick reply to this message
