best muffler/exhaust system! - Page 2 - JeepForum.com
post #16 of 49 Old 01-31-2014, 02:35 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
Hijack alert.... Where do you all have your exhaust exiting the Jeep? I removed a bit of bad pipe and replaced the muffler on mine. Instead of running it up over the axle I used a turn down directly off of the muffler. I hate it. Just not sure if it should exit straight out the back or turn behind the passenger rear wheel?
Back to the OP question. I'm all for the quietest muffler you can find. No one wants to hear us on the trails. Fear the Greenies...
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #17 of 49 Old 01-31-2014, 03:19 PM
AmmitOsiris
Originally Posted by DirtKar
Hijack alert.... Where do you all have your exhaust exiting the Jeep? I removed a bit of bad pipe and replaced the muffler on mine. Instead of running it up over the axle I used a turn down directly off of the muffler. I hate it. Just not sure if it should exit straight out the back or turn behind the passenger rear wheel? Back to the OP question. I'm all for the quietest muffler you can find. No one wants to hear us on the trails. Fear the Greenies...
Mine is all te way out the back, stock location
I WANT WAFFLES..
AmmitOsiris is offline
post #18 of 49 Old 01-31-2014, 03:31 PM
Guns003
Once again, not to hijack but what is the difference between a yj down pipe and a tj down pipe? What does it add or change?
1995 YJ
35" Procomp MT2s, 5.5 inches of lift, RE 4.5 XD, Bilsteins, MORE body lift, Bumpers,TJ flat fender flares, HD steering, Durango steering box, ZJ 136amp alt, Ford 8.8 Rear, 4.56s
Guns003 is offline
post #19 of 49 Old 01-31-2014, 03:40 PM
2013JKRubicon
I had the same question,so I went to youtube and you can pretty much hear any setup you want,I decided when it came down to it Its still sounds like a six cylinder
2013JKRubicon is offline
post #20 of 49 Old 01-31-2014, 04:02 PM
booboowv77
reply to some previous comments,
1.Mine is straight out the back but ends at the rear frame support or factory bumper plate whatever you want to call it, but it does not go past my after market bumper.
2.I have enough done to my motor that I want to hear it and damn does it sound good! LOL!
3.TJ pipe wraps around the oil pan not just straight across. Gets it up Higher
GOOGLE IS YOUR FRIEND!!!
Just my toy!
89 YJ, Fresh 4.0, ax15, SOA w/410's, and about a million other things! :)
Built not Bought #759
booboowv77 is offline
post #21 of 49 Old 01-31-2014, 07:28 PM
Louie4
Run it out the back. I just bought this aftermarket tailpipe from Autozone for under $30. It's a stock replacement and you only have to weld it in. I will probably rent a tube expander then weld it in.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #22 of 49 Old 01-31-2014, 08:52 PM Thread Starter
RCwheelin
What headers are you guys running (yeah I know at the end of the day I still have six hamsters running around my engine block) but just curious
93' YJ
RCwheelin is offline
post #23 of 49 Old 01-31-2014, 10:24 PM
imstillatwork
Ebay stainless steel with flex joints. like this http://www.ebay.com/itm/Jeep-Wrangle...d5a972&vxp=mtr
$80, good enough construction. A die grinder will clean up the inside welds if needed.
Really how can you beat it for $80???
imstillatwork is offline
post #24 of 49 Old 01-31-2014, 10:45 PM
AmmitOsiris
Pacesetter.. Then again I have a 4.2
I WANT WAFFLES..
post #25 of 49 Old 02-01-2014, 12:30 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You are limited to oem replacements here in California.
Anticanman is offline
post #26 of 49 Old 02-01-2014, 12:39 AM
jjlaw72
Not true headers have to have a carb# and bungs for o2s cats have to be California approved cats but everything back is up to you
jjlaw72 is offline
post #27 of 49 Old 02-01-2014, 07:08 AM
Louie4
I'm running one of these. I just wanted a manifold that wasn't going to crack at the collector like my previous two.
I WANT WAFFLES..
If by Pacesetter you mean Walker, then yes waffles it is.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #28 of 49 Old 02-01-2014, 07:13 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
That's correct. Thanks for clarifying. Don't know why I posted that
post #29 of 49 Old 02-01-2014, 07:40 AM
jhrebs
1987 YJ Wrangler
not exactly a muffler question, and dont mean to hijack; I have a hole in my exhaust, before the muffler. So i am going to replace my entire exhaust system, from manifold back. This is entirely new to me. I have a 2.5, fuel injected. It is registered historic, so technically, I do not need a catalytic converter. In this situation, what would you guys reccommend?
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline
post #30 of 49 Old 02-01-2014, 07:43 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Technically you need a catalytic converter because federal laws super cede the state registration.
