Best Fix for Tail Pipe Leak? - JeepForum.com
post #1 of 7 Old 03-09-2013, 11:01 AM Thread Starter
el scorcho
My tail pipe has a leak/hole (size of half a dime) about an inch past the muffler and right up against a hanger. I also think there's a crack in the tail pipe where it meets the muffler, but its obscured by the saddle clamp and a hanger. I'll have to cut off the saddle clamp since the threads and a nut look like they got pop by a cutting torch. Is there a good way to repair both these problems without hot tools? Should I just get a new tail pipe for $40 - $60? With a new pipe should I use a saddle clamp or band clamp, or will the location of the hangers make that decision for me?
How do I remove the old rubber insulators? Do the caps on the end of the rods pop off?
Thanks
el scorcho is offline
post #2 of 7 Old 03-09-2013, 12:08 PM
92 Green YJ
92 Green YJ's Avatar
If it were me I would just weld up the hole. Or yeah, if you cant do that just get a replacement tail pipe
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #3 of 7 Old 03-09-2013, 01:26 PM
TSEJEEPERS
Personally if it was me, I would take it to a muffler shop.
I hate working on exhaust and alot of the time you will spend more time and money than they will charge you.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 7 Old 03-09-2013, 02:06 PM
JBTJ
I fix my tail pipe leaks by replacing them.
JBTJ is offline
post #5 of 7 Old 03-09-2013, 02:27 PM
rubinscube
I would try some jb weld first.
rubinscube is offline
post #6 of 7 Old 03-10-2013, 10:13 PM Thread Starter
el scorcho
I plan on replacing the tail pipe.
1. I think I'll use a band clamp band-clamp.jpg if there's enough space. Any other reason not to?
2. How do I get the old rubber insulators off and and the new ones one?
Thanks
post #7 of 7 Old 03-11-2013, 04:22 AM
bogleparsons
I have used a cut up soda can, some rtv, and 2 hose clamps before
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
