Best Auto Trans if doing swap? - JeepForum.com
post #1 of 2 Old 10-23-2001, 09:47 PM Thread Starter
SFM1AE2
Planning on doing a engine/tranny swap. The engine will be a 350. Whats the best automatic to drop in? I've heard the turbo 350 because its short. Anybody have other suggestions? Also thinking of getting rid of the NP231 in favor of a Dana 20.
87YJ I-6 Offenhauser intake Holley 4bbl MSD 6AL box
SFM1AE2 is offline
post #2 of 2 Old 10-24-2001, 12:13 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I have helped do a similar swap on a YJ already.
The entire process took 2 guys 5 weeks of "after work" and weekends to swap in a Chev 350 with TH350 tranny and an NP203 T-case. We also took the axles from the donor vehicle and put them in SOA configuration. Once that was done, we had a pair of drive shafts made up (didn't align the engine perfect to re-use the front driveshaft), custom designed steering, used a Fargo radiator, mechanical fan on the engine to pull air from the lower portion of the rad, and an electrical fan (manually switched from inside the rig) to push air through the upper portion of the rad.
Since we did that conversion, the owner blew the 350 and is in the process of building a 305 (got for real cheap) and will swap out the NP203 T-case for an NP205.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
Is it easy to swap out my 3speed auto trans for the 4speed auto trans? bhicks TJ Wrangler Technical Forum 15 08-30-2010 10:30 AM
BA-10/5 -Auto Trans swap KillerBBBs YJ Wrangler Technical Forum 1 01-17-2009 08:49 PM
'93 auto trans swap Underdog69 YJ Wrangler Technical Forum 1 11-21-2008 08:13 PM
Swap to an auto trans. Kason Smith TJ Wrangler Technical Forum 2 11-20-2007 03:23 PM
YJ trans swap 5spd to auto???? Rockdaddy YJ Wrangler Technical Forum 1 10-19-2005 11:43 AM
