Best 2 - 2.5 " lift? - JeepForum.com
post #1 of 9 Old 02-04-2002, 08:03 PM Thread Starter
93YJSahara
Decided to lift my jeep finally, any opinions on the best/most complete 2-2.5" lifts?
93YJSahara is offline
post #2 of 9 Old 02-04-2002, 09:34 PM
95yj-4 cyl
The best kit by far within the 2-2 1/2" range is the Old Man Emu kit. This kit is about 2 1/2" tall. The ride is the smoothest I've ever experienced in a YJ and the flex is outstanding too. This kit is a little more than most, but well worth it. I had an OME kit on a previous YJ (the only reason I don't with this Jeep is I wanted more lift than the OME kit gives). Definitely a "2" thumbs up kit.
95 yj, 4 cyl, auto trans, 4:88 gears, detroit front locker, rear detroit with super 35 kit, short shaft conversion, 4" superlift, 32" superswamper radials
95yj-4 cyl is offline
post #3 of 9 Old 02-04-2002, 10:01 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Several of the guys I wheel with swear by the OME kit also - never heard a bad thing about it. In fact, it's the ONLY lift that I've never heard anything negative about.
Steve
OldJeepguy is offline
post #4 of 9 Old 02-05-2002, 12:31 AM
Patton
I have never heard any complaints on the OME kits other than price. I installed a 2.5" BDS system on a 95 two weeks ago and was impressed with the quality of the kit and the low price.
99 tj-3BDS system 3" body 33"bfg's
94 YJ 4.0/3spd dana 60/44 w/35's 9" of suspension lift
Sold-06 TJ X 4spd auto 3.73
Patton is offline
post #5 of 9 Old 02-05-2002, 12:48 AM
Patton
Hello again! jimsoffroad.com has the 2.5" BDS kits and will probably cost under $400 even with shipping. You will need some good quality shocks. I have always used Trailmaster shocks on the kits I have installed for people but, I am sure there are better and maybe even cheaper shocks out there.
Patton is offline
post #6 of 9 Old 02-05-2002, 06:04 AM
hog
I've got the BDS system (lift, shocks,etc), real happy with mine. It rides pretty harsh, (stiffer than the OME kit). Why I chose it was because I carry alot of weight and I was told the springs were rated higher (it rides much nicer with 1000-1500 lbs in the back). I have never heard any bad things about BDS service (automatic replacement), even though I've never had aproblem.
hog is offline
post #7 of 9 Old 02-05-2002, 06:16 AM
Ryan K
I have the RE-XD in 2.5". Its the most complete kit I've seen and has an unbelieveable ride. The only downside is that it is expensive, however it includes everything that you need.
1990 YJ 4.2 3.73 gears with rear True-Trac. 2.5" RE XD w/TJ flares 33 x 10.50 BFG MTs
Ryan K is offline
post #8 of 9 Old 02-05-2002, 09:33 PM Thread Starter
93YJSahara
decisions, decisions, deciions.......I want a complete kit, and a good ride since this is my main form of transportation. The OME kits sounds good but is kinda pricy, and I am hearinf mixed things about the BDS kit. Damn this is a hard decision. Is the BDS kit available with progresive springs? Think if I went with the edelbrock shock it would make a differance in ride? Wife complains about the ride now being harsh, and want a little better ride than stock.
post #9 of 9 Old 02-06-2002, 08:41 PM Thread Starter
93YJSahara
Here's a new twist......I thought my jeep was a little higher than most were stock. I went to a 4X place to see about the BDS kit and got to lookin' at my jeep and realized I have a 2"(thats what the guy said) shackle lift on it. Now what, put stock ones on and go with the 3 1/2" bds? or just add a 1" body lift?
Running 37s on a 2.5" or 3" lift, 1" body lift, and flat flares planman JK Wrangler Technical Forum 44 01-31-2016 09:44 PM
Please noob-proof this setup -2" BB, 1" Body Lift, 1"Motor Lift jondotcom TJ Wrangler Technical Forum 10 03-06-2010 02:43 PM
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Wrangler Technical Forum 4 11-26-2009 07:32 PM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
