bent passenger side upper door half - JeepForum.com
post #1 of 5 Old 08-22-2005, 03:35 PM Thread Starter
trw
2011 JK Wrangler
the passenger side upper door half frame is bent, not severely, but enough to where you have to slam the door to get it to shut, and to where its blows open on anyone trying to open it.
would it be worth the trouble just to replace the frame? or is it to much work and should I just get a whole new upper half with material and all.
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline
post #2 of 5 Old 08-22-2005, 03:51 PM
Alfons
From your description I presume it's a half door with a cloth covered upper that has a bent frame. I have a set of soft doors (the whole door) that are made of bent 1/4 inch steel rod - a work bench, a couple of clamps, hammer and sometimes a torch is all you should need to "re-adjust" the upper door frame - at least that's what I've used to adjust the used soft doors to my jeep and it seems to have worked. I found the torch very helpful in getting the precise bend without forcing it too far one way or the other.
If they're the full steel doors, you'll certainly need something like an oxy-acetylene torch (or something like it) to fix any bends - I'm currently in the process of burning the rust spots out of mine and welding in new metal where necessary (that's why I'm using the soft doors right now).
Alfons is offline
post #3 of 5 Old 08-22-2005, 04:09 PM
LandRover
LandRover's Avatar
When I had the soft upper door halves I bent them in towards the jeep on purpose to get a better seal and less wind noise and rain in the jeep. The only drawback was that whenever my wife tried to open the door it knocked her down
RHD '98 XJ
RE 3.5", Bushwaker Flat Flares,
OR-Fab bumpers, PowerTrax locker,
Sliders, Goodyear Duratrac 33's
LandRover is offline
post #4 of 5 Old 08-22-2005, 04:32 PM Thread Starter
trw
2011 JK Wrangler
Originally Posted by Alfons
From your description I presume it's a half door with a cloth covered upper that has a bent frame. a work bench, a couple of clamps, hammer and sometimes a torch is all you should need to "re-adjust" the upper door frame
you are correct well as far as salvaging the unit, I dont have the torch, but I do have clamps, so I will try, if that doesnt work then I'll look into a new unit.
thanks for the help
Jeep garage:
trw is offline
post #5 of 5 Old 08-22-2005, 09:20 PM Thread Starter
trw
2011 JK Wrangler
well I got it to a much better position now with a mallet, still not perfect but much more tolerable....saved me a couple hundred bucks.
Jeep garage:
trw is offline
Driver side half door upper Jeepman89 YJ Wrangler Technical Forum 2 10-26-2009 07:19 PM
Bent passenger side LCA bracket melcrim TJ Wrangler Technical Forum 4 02-18-2009 09:51 AM
Passenger side Upper Control Arm is FUBAR! Sparty TJ Wrangler Technical Forum 9 07-15-2005 08:26 PM
Where to purchase half upper half door absentiabanish TJ Wrangler Technical Forum 3 04-11-2005 08:26 AM
jeep window driver side upper door half bigdog67 TJ Wrangler Technical Forum 7 06-06-2004 05:44 PM
