Bent fuel line between filter and carb - JeepForum.com
post #1 of 14 Old 01-08-2014, 12:41 PM Thread Starter
kenh
Anyone know where to pick up a replacement, or rig up a new one? The people at Auto Zone and Napa have been pretty clueless so far, and I can't find any replacements online.
Thanks!
'89 Islander - 4.2, MC 2150
kenh is offline
post #2 of 14 Old 01-08-2014, 01:19 PM
jbolty
jbolty's Avatar
Do you still have the stock set up with the filter next to the valve cover, right by the carb?
It's just a barb type fitting, isn't it?
jbolty is offline
post #3 of 14 Old 01-08-2014, 01:20 PM
laffman
I switched to an electric pump years ago and don't remember what it looks like. But does this look right?
http://www.discountjeepparts.com/pro...ducts_id/31301
1990 Jeep YJ Laredo 4.2 I-6
2010 Jeep JK Islander 3.8 V-6
1982 Jeep CJ-8 Scrambler 304 V-8
laffman is offline
post #4 of 14 Old 01-08-2014, 01:42 PM
Old4X
1990 CJ7
It is just a flare fitting. Get a piece of 1/4 inch ID tubing and a flare nut. Cut to fit, put a flare on the tubing, install. Check for leaks
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 14 Old 01-08-2014, 01:52 PM Thread Starter
kenh
The smaller one in there does look like what I need, thanks!
I've never used a flaring tool, so not sure how comfortable I'd be trying to fashion my own.
kenh is offline
post #6 of 14 Old 01-08-2014, 07:27 PM
bigbossd1030
Originally Posted by kenh
The smaller one in there does look like what I need, thanks! I've never used a flaring tool, so not sure how comfortable I'd be trying to fashion my own.
If you bring the tube into any auto repair shop, such as Midas, they will flare it for you. They did my brakes for free. They leaked, but they were free. I ended up fixing them myself. But it could work out for you.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #7 of 14 Old 01-09-2014, 07:09 AM Thread Starter
kenh
Thanks guys, I ended up trying to fashion my own last night with a length of tube that already had a flare and flare nut on it, and the place loaned me a tube bender and flare tool. The flare tool ended up being easy enough(seemed to anyway, I never hooked it up to see if there leaks), but the bender tool was a real POS and I ended up crimping and breaking the tube, so I'm going to give it another shot tonight going really slowly with the bending.
kenh is offline
post #8 of 14 Old 01-09-2014, 10:26 AM
bpounds
bpounds's Avatar
Sliding a coil spring over the tubing will keep it from kinking on you. Just find a spring that fits nicely on the tube.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is online now
post #9 of 14 Old 01-09-2014, 05:53 PM
bigbossd1030
Not the metal tube it won't. Nvm I see what you mean. Would have to be a strong spring no? What about a small amount of heat? Small plumbing torch should do it.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #10 of 14 Old 01-09-2014, 06:23 PM
jay-h
Can't you use fuel hose?
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #11 of 14 Old 01-09-2014, 06:27 PM
bigbossd1030
not on this particular job. It's a threaded fitting he has to connect to. It seals just the same as your brake lines do.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #12 of 14 Old 01-09-2014, 06:46 PM
Old4X
1990 CJ7
Put a stub piece in and attach rubber hose to it and to the filter
Old4X is offline
post #13 of 14 Old 01-09-2014, 06:50 PM
bigbossd1030
Don't have to convince me, if I was looking at it, I'd do the easiest way that was available to me.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #14 of 14 Old 01-10-2014, 07:07 AM Thread Starter
kenh
Not sure why I didn't think of that earlier, but that definitely sounds like the easiest route. That being said I think I got one made last night that will work, if not I'll go the stub route with rubber hose.
kenh is offline
