bending shift lever - JeepForum.com
post #1 of 4 Old 03-27-2013, 08:21 PM Thread Starter
Reno72
bending shift lever
I added new seats and they ended up being a lot wider and bigger than stock. I'm really happy with them except for one problem/irritant, when shifting to 2nd gear the knob hits the right front cushion. Not a big deal but it bothers me. How difficult is it to bend the lever forward/straighter? anybody done this?
Reno72 is offline
post #2 of 4 Old 03-27-2013, 09:43 PM
jokerchief462
It's been done before for the same problem seat clearance. It would take some heat to get it bent correctly. Maybe drive it to a welding shop or some one with a torch. Remove the shifter heat it up and bend.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 4 Old 03-27-2013, 09:58 PM
bigbossd1030
It's really as simple as that. I wouldn't imagine a welding shop would even charge you. You probably could do it with a propane torch and a vice, but it would take a lot for it to get hot enough from a bottle that most have at home. An acetylene torch will make quick work of that. Literally 60 seconds and its done.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #4 of 4 Old 03-28-2013, 04:25 AM
bogleparsons
I used a propane torch and a pipe wrench get it red hot.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
