belt problems - JeepForum.com
post #1 of 3 Old 12-12-2011, 09:41 AM Thread Starter
reddog749
belt problems
hey guys, im new here and need some help, i just bought a 91 yj that someone did a 2.5 to a 4.0 engine swap,the problem is it keeps eating the belt, doing limited searches on line the only thing i could find is that the balancer is different, any and all help is useful thanks in advance Mike
reddog749 is offline
post #2 of 3 Old 12-12-2011, 10:39 AM
94chb
you need to look from the side of the engine and the pulleys and see if they are lined up.
94chb is offline
post #3 of 3 Old 12-12-2011, 10:58 AM
Que89YJ
The crank pully is a 2 piece seperated by rubber. The rubber is probably bad inbetween and letting the pully flex. If everything looks like it's lined up check the harmonic balancer pulley.
Que89YJ is offline
belt problems again jeepasaurus TJ Wrangler Technical Forum 1 10-04-2011 11:06 PM
95 YJ belt problems divewall14 YJ Wrangler Technical Forum 0 04-06-2009 04:21 PM
Belt Problems 97casteeltj TJ Wrangler Technical Forum 5 01-24-2008 05:58 PM
Belt Problems??? dwillz07 TJ Wrangler Technical Forum 4 01-09-2008 05:14 PM
fan belt problems DieselWrangler TJ Wrangler Technical Forum 8 03-05-2006 07:42 PM
