belt mis-alignment - JeepForum.com
post #1 of 10 Old 12-16-2011, 06:44 PM Thread Starter
JohnnyB79
belt mis-alignment
1990 sahara 4.2
The a/c compressor sticks out too far and throws the serp belt out of alignment. Eventually the belt comes off. Any suggestions? I bought the jeep used.
JohnnyB79 is offline
post #2 of 10 Old 12-16-2011, 06:58 PM
jbolty
jbolty's Avatar
pictures? stock a/c?
jbolty is offline
post #3 of 10 Old 12-16-2011, 07:04 PM Thread Starter
JohnnyB79
I dont think it is stock but not sure. Will get pics tomorrow, it's dark now.
post #4 of 10 Old 12-16-2011, 07:23 PM
superj
Shim it back to where its properly aligned. Or shim the others forward. I had to shim my waterpump pulley out so my belt didn't squeek
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #5 of 10 Old 12-16-2011, 07:41 PM Thread Starter
JohnnyB79
cant shim it back b/c the way it bolts to the bracket
post #6 of 10 Old 12-17-2011, 07:40 AM
CJ51973
CJ51973's Avatar
check all the accessory brackets for cracks, missing bolts, etc. I had to do some welding on my alternator bracket.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #7 of 10 Old 12-17-2011, 10:57 AM Thread Starter
JohnnyB79
post #8 of 10 Old 12-17-2011, 10:58 AM Thread Starter
JohnnyB79
post #9 of 10 Old 12-17-2011, 01:14 PM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
That looks like your PS pump that is too far forward. The rear has two bolts that mount it to the bracket. The one closest to the camera is either loose or not set in correctly OR the PS shaft is going.
THAT is just my opinion based on the picture you took.
Had same issue on my 88...well...sort of.
Axles and bolts and springs....Oh My!
My Build Thread --->>>
Not my write up, but now one of my jeeps losing a BA and gaining an AX->
hotelconucc93 is offline
post #10 of 10 Old 12-17-2011, 01:53 PM
timatoe
timatoe's Avatar
How about a pic from the other side? If you think the a/c compressor is too far out, it's gonna be hard to say looking from the other side.
timatoe is offline
converting a York v belt pulley to serpentine belt Dre40 YJ Wrangler Technical Forum 8 03-07-2016 12:19 PM
Alignment or aussie locker? Alignment specs included. CrawlerYJ YJ Wrangler Technical Forum 24 02-17-2011 09:21 AM
Belt squeal, new pulleys, belt, alternator private TJ Wrangler Technical Forum 0 01-17-2011 09:16 PM
Major serpentine belt alignment issues after York install liljpy TJ Wrangler Technical Forum 28 06-08-2010 12:50 PM
Belt Alignment Problem deepcreek TJ Wrangler Technical Forum 3 05-26-2009 09:29 PM
